Thread: Need some advice please
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    Default Need some advice please
    Looking at getting a compressor and found one fairly cheap, the only thing im a little unsure of is the hose fitting on this picture
    I thought compressors only came with these sort of connections
    Can anybody clarify how to couple hoses onto the taps above, or can i just swap for the quick couplers(2nd pic)?
    cheers
    Regular Member megsdad's Avatar
    May 2011
    Northwich, Cheshire..
    15 Post(s)
    Vehicle : SRi Estate Nav
    Trim : Boring cloth
    Engine : CDTi 150
    Ive just looked on my compressor(its similar to the pictured one) and the PCL push fit fittings will screw in if you removed the hand lever valves...
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    That looks different to the usual connectors! Looks as though you push the pipe on to them then clamp with a jubilee clip. Aldi are doing a 2.5 hp compressure just now for £100 with a 3 year guarantee
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 79000
    this is all the info it has
    • 230v/50Hz
    • Capacity: 0.11M3/min
    • Tank Capacity = 50lts
    Pressure: 115psi (8 Bar)
    • Air Displacement: 206L/min
    • Speed: 2850RPM
    • Current: 7.5A
    • Input Power: 1500W
    • Output Power: 1050W
    Weight: 33kg
    • Sound Level: 82dBA
    • Oil: synthetic (included)
    • Oil grade pump: SAE 5 W 50
    • Required oil quantity (pump): approx. 0220
    Dimensions: 27"(L) x 31.5"(H) x 12"(W)
    • 13 amp Plug Fitted/2 x wheels
    • CE Approved
    Norwich
    Trim : SXi
    Engine : 2.2
    Those fittings are industrial quick connects
    You can get 1/4" or 3/8" NPT fittings with the same airline fittings as the compressor above so you could change them over/
    VIP-Member Z80's Avatar
    Apr 2008
    Noumea
    14 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Actually those nipples are meant to fit hoses directly with a clamp ring. On the other side of the hose, you'll pu another nipple connector with a female quick coupler on the other side.
    Since I'm at my office right now, I could take a picture of the compressor we use to clean up computers, having managed to show both hose ends on the same picture for you to see...
    1/8 or 1/4 NPT stuff concerns threaded parts only. BTW, the nipples here are fastened by pressure nuts, and not threaded at the rear.
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 79000
    cheers guys for the advice
    Apr 2008
    Noumea
    14 Post(s)
    Trim : Elegance
    Mileage : 75 000
    Went to the hardware shop this morning and they sell hoses assemblies with a crimped quick coupler. Should be more handy than the nipple coupler on this side, as the clamp sometimes comes in the way when disconnecting devices.
  1. ebay advice , think someone is trying it on , need advice ...
    By poves in forum General Motoring Chat
    Last Post: 22nd August 2012, 00:29
  2. Newbe after advice, lots of advice!
    By rb199 in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2011, 19:08
  3. Please need Advice
    Last Post: 16th October 2010, 19:21
  4. Need some advice
    By Ralphwells1967 in forum General Chat
    Last Post: 10th June 2010, 11:24
  5. New Car advice really
    By Perry in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2008, 21:53
