07 plate Vectra has sailed through mot...
after the brake test the abs light is now on and not going off!!!
wtf there was nowt up with it before the test???
Quite common when a cars been on rollers of any kind, more common on rolling roads, I've not heard of it happening on a brake tester before.
Basically the system detects the front wheels rotating and not the rear and disables the system automatically as a safety precaution. It should reset after a couple of miles driving, if it doesn't then try pulling the battery off for half hour or so. If it's still on after that, then the garage has stuffed a sensor or something doing their inspection.
Maptun Tuned 2.0T Estate - click HERE for mods list.Brentwood 2012: Winner, Saturday Show. Hull 2012: Winner, Best Estate. Hull 2013: Winner, Best Estate & Runner Up, Best I.C.E
Think top ones the issue...
the other 3 are me turning ignition off while rolling to attempt to clear light???
We've cleared faults, touch wood ATM not has come back...
only done a couple of miles so will see???
What Ian said, the ABS system gets confused because the front(or Rears) are turning but the rears are not, and throws a wobbly.
It's back on and not clearing now...
Sorted now I think...
Jacked car up to check connection on inner wing.
Noticed a blue wire broken going into the connector ( car loom side, not sensor side ).
Soldered it up quickly for now, will add a little extra wire in when I wip wheel off to change the drop link...
