Thread: Z30DT - engine performance sometimes flat (DTUK green fitted)
    Sep 2011
    Winsford, Cheshire
    Default Z30DT - engine performance sometimes flat (DTUK green fitted)
    Hi all,
    I've got a 2006 Z30DT 184PS with just under 60k on the clocks. It has just had a full service including fuel treatment. Always run on Shell diesel (std, not vpower).
    I have recently fitted a DTUK green box and the performance is way, way better about 90% of the time, but then the other 10% or so the turbo still comes on boost, it still pulls but it can best be described as flat (not hesitant). Almost as through the tuning box has been turned off.
    I can normally overcome this by simply switching off the engine and re-starting again, then it becomes lively again.
    I'm not really familiar with what to check or clean on this particular engine, are there any sensors or valves that are worth checking and cleaning?
    This was an issue this morning when safely overtaking a car, and my car failed to deliver the performance I expected so I was alongside for longer than I wanted to be.
    Thanks in advance guys.
    ps I have the tuning box set to "A" at the moment, after going through settings 7, 8 and 9.
    South Central England
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    A would be 10 then, which is quite high and the ECU might be unhappy with the discrepency between pump indicated output and common rail pressure, resulting in it reverting to using the pump indicated output values. Best thing to do is turn it down a bit I'm afraid.
    Sep 2011
    Winsford, Cheshire
    Quote Originally Posted by nutron View Post
    OK I think I understand, thanks for your guidance. I think the tuning box can go up to letter F so its got another 5 clicks before full power.
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Turn box down and try again.
  1. dtuk red or green
    By marc vectra sri in forum Diesel Engine related
    Last Post: 28th November 2012, 10:33
  2. dtuk green or red box ????
    By paulf in forum Diesel Engine related
    Last Post: 23rd August 2012, 08:59
  3. For Sale: DTUK Green Box Z30DT
    By LeeU in forum Parts for sale
    Last Post: 26th September 2011, 16:11
  4. Whats the difference between dtuk green and dtuk red?????
    By srinav in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2011, 10:04
  5. DTUK Green
    By Joeblack in forum Diesel Engine related
    Last Post: 1st May 2008, 23:03
