Thread: handbrake
    Regular Member jamiedvvt's Avatar
    Sep 2012
    Inverclyde
    Vehicle : Vauxhall Vectra
    Trim : Sri
    Engine : 1.8 vvt
    Default handbrake
    Changed the back brakes today and everything went well stops a little better now but have problems with the handbrake i have to pull the lever all the way to the top now and the car still creaks back a little bit which it didn't do before can someone help thanks
    Jun 2009
    birmingham uk
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Mileage : 106000
    Mine did exactly the same after replacing the rear pads, settles down with use, some one suggested to me handbrake off and pump the foot brake hard. I think the best you can do is just make use of the handbrake a lot The self adjusting pistons eventually unwind and take up the play.
    Dec 2010
    London
    6 Post(s)
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    when replacing rear pads i always pump pedal 30ish times BEFORE touching handbrake
    crook
    could be a stretched handbrake cable ...
    How far your handbrake come up before pad change ?
    Or could be the auto adjuster on the handbrake(mines gone) Stealer part £££££££££££ full handbrake jobbie
    Sep 2012
    Inverclyde
    Trim : Sri
    Engine : 1.8 vvt
    Yeah I done that pumped the pedal a good few times before applying handbrake, the lever stopped just over half way with the old pads and now it goes all the way up
    crook
    Sounds like handbrake auto adjuster.
    if you remove rear of centre console ( there's a how2)
    When pulling handbrake you will see auto adjuster not taking up slack on cable.
    If you hold end of cable with pliers or locking grips with handbrake on .
    Then let handbrake off but try and keep and of cable where it was you will hear auto adjuster ratchet up.
    Try using car with cable ratcheted up and see if it slips back.
    If it slips its scrap yard time (£190 stealer for complete handbrake )
  1. Handbrake
    By bobbleheadbarney in forum Suspension, Wheels & Brakes
    Last Post: 16th December 2012, 19:22
  2. Handbrake
    By conman in forum Handling & Braking
    Last Post: 11th December 2012, 20:11
  3. handbrake
    By Swedge in forum Suspension, Wheels & Brakes
    Last Post: 15th November 2012, 20:44
  4. handbrake
    By richje100 in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2010, 21:46
  5. Handbrake.
    By teilo in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2007, 20:29
