Results 1 to 10 of 11
Thread: Towbar Electrics
    southampton
    Default Towbar Electrics
    After trawling the internet, there doesn't seem to be a definite answer on how to connect the electrics.
    There's lots on fitting a genuine bar and electircs. (just plug it in).
    But fitting a bypass relay is a different question it would seem.
    With a 55 reg vectra c, with the bulb failure system etc, where do you wire the bypass relay? Can it be wired into the black socket in the boot under the hidden pocket, and then simply install a fuse to activate. Or does it need some sort of module to activate this plug?
    It seems very vague on wiring one of these relays, as most seem to opt for the genuine item. But at 120 quid, i think vauxhall can do one.
    Any help on retro fitting the electrics is much appreciated, because if i put a metre on say the rear cluster on the pillar (estate) then the metre gets mixed signals when testing between indicator and side lights. Most weird!
    Does anyone have a clue on which plug out of the back fuse board controls what? Pictures or diagrams would be helpful, as there is a severe lack on the internet.
    Sep 2012
    dewsbury
    Vehicle : Vectra C Hatchback
    Trim : Sri
    Engine : 1.8 vvt
    Year : 06
    A job I need to do myself at some point. The bypass relay gets its power via a feed straight from the battery and the wires splice into the relevant lighting wire. The wires from the trailer socket connect to the relevent connecter on the relay following the wiring diagram. I've got a page with a good set of instructions bookmarked on the pc so I'll post the link when I can
    Mar 2013
    south wales
    Vehicle : vectra c
    Trim : sri
    Engine : 1.9cdti
    Year : 57
    mines a 57 plate and I don't have a bypass relay there connected strait into the wires on the car loomb with no bulb failure light hope this helps
    southampton
    I've just cut the plug off and wired the relevant wires to the bypass relay.
    I still haven't got a live supply though, even though the red cable to the plug is meant to be permanent live. (which is where i want to feed the bypass live from). rather than having to feed a separate one. but obviously there must be a space in the fusebox to activate this red cable?
    southampton
    UPDATE
    I have just tested all connections from the plug in the bottom of the boot, and there is zero to any of the cables. I assume you do need one of the trailer modules check control things? Is it part No. 90463123 that i need to activate these cables?
    Sep 2012
    dewsbury
    Trim : Sri
    Engine : 1.8 vvt
    Year : 06
    http://towsure.blogspot.co.uk/2007/1...ass-relay.html
    That`s the best page I`d found for instructions. The relay I got came with an extra fuse and enough wire to run right to the battery although I did think about splicing into the red feed wire to the fusebox in the boot for the power
    southampton
    Quote Originally Posted by bishy15 View Post
    Sorry if i'm being dumb! Do you mean you just wired the bypass relay onto the harness that's already live, as opposed to what I've done by trying to utilise the trailer plug (X24 connection)?
    And no buld failure light, means that you don't have any nuisance bulb warnings?
    southampton
    Quote Originally Posted by jason johnson View Post
    Yeah i think i need to ditch trying to use the plug and just wire it straight into the car loom.
    Does anyone know if the wire colours on the black plug are the same colours used for the rest of the rear lighhting? i.e. black/yellow being brake light, black/green right indicator.... and so on and so forth.
    Another thread you might be interested in is :http://www.vauxhallownersnetwork.co....wiring.158357/
    Regular Member LGaffer's Avatar
    Dec 2012
    Castleford
    5 Post(s)
    Vehicle : Vectra C Preface
    Trim : SRI
    Engine : 1.9 cdti 150
    We did the same on my dad's veccy last year. We just scotch locked the wires directly to the wiring loom in the boot. We found out which wires went where by looking at the wiring behind the rear cluster board. No problems with bulb error either.
    Sep 2012
    dewsbury
    Trim : Sri
    Engine : 1.8 vvt
    Year : 06
    I may be wrong but I think I`ve seen something somewhere about the trailer module needing activating by tech2, it might depend on if the car is a half or full canbus
  1. Towbar electrics
    By jofenan in forum Electrical & ICE (including SatNav)
    Last Post: 12th October 2011, 16:21
  2. towbar electrics
    By alex32 in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2011, 19:40
  3. Towbar Electrics
    By slipperysam1984 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd June 2010, 15:53
  4. Towbar electrics
    By CPHB in forum Electrical & ICE (including SatNav)
    Last Post: 14th July 2005, 21:28
vectra c towing module activation site:www.vectra-c.com
vectra c which wires to splice into towbar
vectra c towbar activation
