Results 1 to 3 of 3
Thread: Front brake sensor
    Oct 2012
    staines
    Vehicle : Vectra c
    Trim : Saloon
    Engine : 1.8
    Year : 2002
    Mileage : 101000
    Default Front brake sensor
    I changed the front brakes on my vectra and noticed the brake sensor had been cut. Iv always had the warning light on the dash, the problem I have is I can't find the wire coming from power source to the cut sensor in order to replace the sensor can anybody help
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    There should be a cable following a similar path to the front left brake line, but stopping at a socket, mounted to the same bracket as the brake line. The pad wear sensor plugs into that.
    It's a fairly lightweight, black cable.
    If you don't have that, I would guess either the cable has been ripped or cut off previously, or if you're lucky, just tucked away. You're probably looking at removing the wheelarch liner to hunt it down.
    newport
    or you could just join the wires together for now, thats what i have done with ours until i get new discs and pads,
    edit:- scrap that, just re-read your post
  1. Fitting & Installation of ABS Harness & brake Help sensor sensor
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 20:46
  2. front brake pad warning sensor
    By darkmandonny in forum Suspension, Wheels & Brakes
    Last Post: 5th December 2009, 13:03
  3. Front Brake Pad Sensor Part 13139269
    By Padster72 in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2009, 10:07
  4. BRAKE LINING FRONT WEAR SENSOR Vauxhall VECTRA-C
    By Fedex in forum Suspension, Wheels & Brakes
    Last Post: 13th February 2009, 14:09
  5. Front Brake Pad Sensor
    By bandrew in forum Suspension, Wheels & Brakes
    Last Post: 30th August 2007, 09:11
