Results 1 to 10 of 16
Thread: Noisy Back End
    Mar 2013
    reading
    Trim : sri
    Engine : 1.9 cdti 150
    Default Noisy Back End
    Hi,
    Got a cheap 05 pre facelift Vectra 1.9 CDTI 150, and encountered problems with it, as expected with the value i paid. Engine ones are complete or in process of being dealt with now its time to address the others, which i wish people can help me.
    I have a noise coming from the back end, I would describe it thudding/banging/like a spare wheel in the boot banging about on the metal bottom.
    Of course i have emptied boot, checked exhaust.
    I jacked up and found that rear left brake caliper is ceased. I spin the wheel and it stops within 2 seconds.
    Also noticed both tyres, have inside wear.
    Mainly the noise is at slow speeds, not neccesarily over bumps. I go on a 30mph road for example and not a noise to be heard.
    No whirring sounds, like bearings...
    Any ideas etc
    Cheers in advance
    Jul 2011
    UK
    Year : 06
    sounds like banana arms bushes have gone control arms
    Mar 2013
    reading
    Trim : sri
    Regular Member concretefingers's Avatar
    Jan 2013
    Sutton Coldfield
    Trim : Breeze
    Engine : CDTI 150
    Mileage : 137K
    I had that problem.mine was a easy cheap fix. the boot hatch was bouncing up and down. at higher speed the wind presses down on it keeping it closed. if you lift the hatch you will see a couple of plastic stops that can be adjusted. I just loosened the locking mech, shut the boot then reopened and locked them off.
    Mar 2013
    reading
    Trim : sri
    i actually thought that at first. but one person sat inside and one person closed boot, then tried to move it up and down to see if made noise, but seems not.
    Im guessing with the wear of tyres its related
    Mar 2013
    reading
    Trim : sri
    are there 2 control arms, upper and lower on each side of rear axle?
    Regular Member beat275's Avatar
    Aug 2011
    Newcastle West Denton
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    could be the shocks or arb bushes
    Mar 2013
    reading
    Trim : sri
    right, i believe there are 2, 1 upper and 1 lower.
    lower
    upper
    which one is more than likely to be?
    any way of checking for faulty ones
    Aug 2011
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    never seen that lower 1 but could be wrong
    Mar 2013
    reading
    Trim : sri
    update: on you tube there was a guide to check for movement etc;
    * Told whilst car on floor, to hold the top of the tyre and move back and forth.
    What i found was the rear left side, had movement back and forth, enough and i could hear a noise. Sounds like the one.
    Would this be the banana, upper control arm
  1. noisy cat
    By vectrabtcc in forum Engine & Drivetrain
    Last Post: 15th February 2012, 10:51
  2. Noisy Top End
    By viper8 in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2011, 09:45
  3. noisy air con
    By John35 in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2007, 14:14
  4. Noisy car help please
    By Higgins in forum Engine & Drivetrain
    Last Post: 28th February 2006, 22:27
  5. Noisy back brakes
    By KC in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2006, 14:47
