Thread: Removing the pre-cat on a Z19DTH (and smashing the insides out!)
    Full Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    Default Removing the pre-cat on a Z19DTH (and smashing the insides out!)
    Hi guys, I'm looking to remove the pre-cat on my 07 vec over the Easter weekend (I have the z19dth), it will involve me removing most of the exhaust as I'm upgrading and while I'm there I'm chopping the main cat out, now this is all fairly straight forward but I'm looking for advice regarding the pre-cat.
    I intend to smash the insides out however is it best to remove the pre-cat from the turbo or can it be done in place easier enough? If I remove it to complete the job what's needed with regards to gaskets etc for refitting?
    Also what's a good way to remove the insides, a big drill bit or a hammer and chisel?
    My z20let was a pain in the rear to get it to seal again after having the pre-cat off and I want to avoid this if possible!
    Any help from those more experienced is greatly appreciated!
    Regular Member Learch's Avatar
    Jan 2013
    Chester
    Vehicle : Vectra c
    Trim : LS
    Engine : Cdti 8v
    I'd take the pre cat off as the amount of beating you will give it is likely to crack something as the casting on the turbo isn't designed to take repeated shock.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    I would remove it i did my old 1.9 while still on the turbo and 3 months later the turbo went im not saying it was cos of all the vibration but better being safe than sorry.
    Norfolk
    Mileage : 69'000
    Ok sounds like good advice! What's needed with refitting the pre-cat, gaskets etc? Possible to re-use the old ones or do you need new?
    And I will remove the 02 sensor before the bashing begins lol.
    Moderator paulhb's Avatar
    Wondering lonely as a cloud
    27 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    A new triangular gasket is a wise move and not expensive, the clamp between the turbo and the precat pipe can get rusty a new one is about £6 and saves grief if you need to cut the old one off, I brought a new one as replacing the turbo in a couple of weeks time.
    Norfolk
    Mileage : 69'000
    Cheers for the reply Paul, so there's no gasket between the turbo and pre-cat?
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    244 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    The joint between the turbo and pre-cat is a conical flange clamped together with a ring-type compression clamp. It just needs to be thoroughly cleaned with a wire brush and then wiped with brake cleaner to ensure a good seal.
    Norfolk
    Mileage : 69'000
    Good to hear, thanks very much. The pre-cat on my Z20LET also had the same type of flange but it did have a gasket in there too so was just making sure, good news I found the triangle gasket for a couple of quid!
    Worth me doing a how-2?
    27 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Always worth a How 2 someone else might need some guidance!
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    I found it a pain to split the turbo from the pre-cat and that was the turbo off the car as the spring clamp is a tough git to open lol
  1. Smashing Lamborghini
    By fingers66 in forum The 'Off Topic' room
    Last Post: 17th March 2011, 22:08
  2. following HOW 2, EGR clean, solenoid insides not budging
    By vectra-probs in forum Engine & Drivetrain
    Last Post: 6th February 2010, 19:30
  3. The insides of a 3.2 V6 Engine
    By BlueRob in forum Engine & Drivetrain
    Last Post: 17th September 2007, 16:32
  4. 2.0t still broke thinking off smashing up as had enough.
    By rickyroo in forum Engine & Drivetrain
    Last Post: 4th September 2007, 08:54
  5. Penguin Smashing
    By R-man in forum Comedy & Humour
    Last Post: 30th November 2005, 00:13
