Results 1 to 10 of 20
Thread: headlight question
    Regular Member tj56's Avatar
    Apr 2008
    Tyne and Wear
    Default headlight question
    Hi guys, its been a while but ive found this site to always be a great source of help when needed so thanks in advance.
    My question is this, the missus car (facelift SRI) has a dodgy indicator on the passenger side. the bulb housing is knackered and the contacts aren't allighned properly, think its been off before and damaged, so sometimes it makes contact and its fine but go over a bump and its off again, ive had the headlight out and tried my best but tbh im looking to get a replacement and be done with it. if i were to get a used one and say the level was off as in different to the drivers side setting, will it auto correct or set back to default when fitted into the wifes car?
    cheers
    Rob
    13 Post(s)
    No, a replacement headlight will need re-aligning.
    You could take a measurement of the existing headlight beam by parking at a set distance from a wall / fence / garage door and drawing where the horizontal beam is and the exact place where it kicks up, then fit the replacement headlight and check/adjust it to the markings on the wall / fence etc.
    Ultimately though, it would be better to put it on an MOT beam tester.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Is the indicator bulb holder not at fault, recently had replacement lights and the holders were terrible, they were a poor fit and required some adjustment of the prongs (tech term) to make fit so they would work 100%. Does the other side one work fine (to test the theory)?
    Apr 2008
    Tyne and Wear
    Thanks Dave. i had thought if i fitted it then set the light level back to 1 it would travel all the way down and kind of reset.
    cheers
    Apr 2008
    Tyne and Wear
    its exactly that Dan, although not a replacement light, its the orig one, the indicator went off so i thought it needed changed, took it out and it was fine. when replacing the holder i noticed the prongs were bad so tried to fix them but like i said, sometimes they make contact and sometimes they dont. there not the best.
    so been looking for replacement holder
    13 Post(s)
    Quote Originally Posted by tj56 View Post
    cheers
    The replacement headlight shouldn't be that far out. You might be lucky and it will be spot on.
    Lancashire
    Trim : XP1
    Mileage : 66000
    Ah right, cool.... I just thought a replacement headlight was a bit much when it "could" be the holder itself.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I had the same problem with my car and it had arc'd that many times there was a small hole through the contact on the bulb holder. Fitted a new one and it's been fine since
    Apr 2008
    Tyne and Wear
    Quote Originally Posted by John IS3 View Post
    thats what im guessing is gonna happen with this one, im busy trying to get one for 30 quid from a local seller so if i can get it then its worth it imo, nothing worse than turning left with no front indicator...
    Apr 2008
    Tyne and Wear
    looking for used one Dan
  1. Headlight question
    By Kenny_Exclusiv in forum Electrical & ICE (including SatNav)
    Last Post: 2nd October 2012, 13:03
  2. headlight question
    By james23 in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2012, 21:38
  3. Headlight question
    By gavs-sri in forum Electrical & ICE (including SatNav)
    Last Post: 15th April 2012, 19:57
  4. vec C 04 reg headlight question
    By mick.n in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2010, 14:01
  5. Headlight Question
    By Bethan39 in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2005, 18:59
