Thread: electric windows
    Regular Member azacbr6's Avatar
    Dec 2010
    chesterfield
    Default electric windows
    Is there anyone with more knowledge than me with auto electrics, the wife’s skoda fabia 1.2 htp 2007 front windows stopped working (front electric windows only), I took the driver’s door card off and checked for water ingress, shafing wires etc and everything seem to be ok, Now I don’t think it’s the double switch because the passenger door also don’t work, unlikely they both stop working together, I don’t believe it’s the convenience control unit as I was told these are very durable/reliable unlikely to break as they are situated well away from wet and grime (but you never know), the thing that’s left is the window motor which has an integral control unit which also controls the other door’s motor. The question is how I test this motor to see if it works, there are no wires coming out of it so I don’t know where to connect a wire run from the battery to test it. And also how do I check the windows double switch is working? I think all cars electric window systems are basically the same and hope your vast knwledge with vectras will be helpful as I dread what a dealer will charge just to look at it
    thanks.
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    Reading your post you never mention a fuse,any chance it could be as simple as.....
    Dec 2010
    chesterfield
    Sorry mate, I didn't mention it but It was the first thing I've checked, I even put 2 new fuses just in case the old ones were dirty or didn't fit well. I am 90% sure it's the motor/control unit assembly but they are expensive to buy and I need to make sure it is the right part I am changing. apparently all VW, seats, audis, skodas..suffer with electics, had 2 vectras and never had a problem.
    Jun 2011
    Vehicle : vectra
    Year : .....
    Thought you would've,had to ask mate cos you never know
  1. electric windows help
    By leedslads in forum Electrical & ICE (including SatNav)
    Last Post: 24th September 2012, 17:37
  2. Electric Windows
    By jctjohn in forum Electrical & ICE (including SatNav)
    Last Post: 5th June 2011, 15:09
  3. electric windows
    By rozzer2006 in forum Electrical & ICE (including SatNav)
    Last Post: 11th October 2009, 10:34
  4. electric windows
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2008, 18:15
