Thread: hydraulic tappets?
    Sep 2010
    Tranent
    Default hydraulic tappets?
    iv started getting a tapping noise which used to happen to my old astra when it was running low on oil,more oil used to help the problem,so today on my 1.8sri 55 plate i tried the same after topping the oil up (i have to say it was pretty low!!!) and after a 20 mile drive problem persists is it possible that a longer drive may be needed?? my friend seems to think it may be the hydraulic tappets and an oil filter change along with some quality oil may help any ideas??
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    24 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    ID LISTEN TO YOUR FRIEND...maybe even use an engine cleaner to flush the old out.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    change the filter... leave the old oil in but top it up to about half way up the dipstick... throw some good quality flush in and follow the instructions.... then do a full oil/filter change with some quality oil.
    Sep 2010
    Tranent
    on another forum i read somewhere that the engine may be knakd with similar syptoms is it an expensive job if oil/filter change etc doesnt work?
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by scarface0004 View Post
    Post a sound file of the engine on here, would be better to hear the noise.
    Dec 2011
    Seaham
    If it is a VVT it is possile the Cam Phaser solenoids are starting to fail, normally get a rattle on start up. I did a How 2 on removing the solenoids to take the filters off. If the car hasnt had a good service history then the filters may be blocked.
    For a 20 minute job, they are worth checking.
    I would also recommend an engine flush and refill with the right grade oil.
  1. Tappets and cams??
    By Froggy in forum Engine & Drivetrain
    Last Post: 20th February 2013, 16:06
  2. Bonnet hydraulic arms?
    By Danny87 in forum Vectra C / Signum Car Chat
    Last Post: 21st August 2012, 07:47
  3. For Sale: Shimano mtb hydraulic brakes £65 del.
    By OPC in forum General items for sale
    Last Post: 22nd June 2012, 20:53
  4. z20net tappets
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2012, 21:28
  5. Hydraulic Bonnet Lifters?
    By Dominic Brown in forum Bodywork & Interior
    Last Post: 16th November 2007, 12:00
vectra vvt tappets
noisy tappets on astra sri 1.8
