Thread: 1.9 8V CDTi lumpy take off EGR related possibly
    Mar 2013
    Warrington
    Engine : 1.9 CDTi
    Default 1.9 8V CDTi lumpy take off EGR related possibly
    Hi folks,
    back in a griffin now since the sale of the v6 but have gone to the fuel of satan.
    Diesel with 110k and FSH.
    Started getting really slow off the line and a bit lumpy between 2-3k rpm. No smoke at all and the turbo is boosting fine (can hear it spooling).
    Spanner light comes on and when i plug my mac scanner in I get P0400 - EXHAUST GAS RECIRCULATION FLOW.
    MPG has also gone down.
    Took the EGR valve off and gave it a good clean (after reading previous threads). only im not sure how far the valve is meant to open/close. when i trued to operate it manually by hand it barely moved and just clicked.
    put it back on the car with hardly any difference apart from my car sounding like it has a little dump valve on it. It was definitely the EGR i took off and cleaned (top right hand of engine when looking at it) held on by 3 13mm bolts and 2 exhaust style flanges.
    Still getting the spanner light on and P0400 EGR Flow message but it comes and goes but always runs lumpy regadless.
    Not sure where the vac pipes are etc so if anyone can supply pics id be very grateful.
    Regular Member Vectra-c-SRI's Avatar
    May 2008
    Near Glasgow
    Engine : 1.9cdti 8v (120bhp)
    Mileage : 98000
    Yeah you did the EGR but I used toothbrush n carb cleaner.
    http://www.vectra-c.com/forum/showth...ur-EGR-1-9cdti
    and if still a problem try this... This will make it like New.
    http://www.vectra-c.com/forum/showth...proper-method)
    heres the pdf for the above http://www.vectra-c.com/forum/attach...7&d=1232829228
    Heres more info for you...might fix the problem
    http://www.vectra-c.com/forum/showth...-1500-2000-rpm
    May 2008
    Near Glasgow
    Mileage : 98000
    Also did you clean the boost value that's little black plug to the left of egr
    May 2008
    Near Glasgow
    Mileage : 98000
    Clean throttle body. And check the main board for solder cracks.
    http://www.vectra-c.com/forum/showth...-body-CDTI-150
    May 2008
    Near Glasgow
    Mileage : 98000
    Sorry for all the posts have you tryed disconneting the egr and drive to see any difference .. i have still to do most of the above did egr. Boost sensor. About year ago now am at 93k think I will do the lot when I get s dry day
    Mar 2013
    Warrington
    Engine : 1.9 CDTi
    Thanks for the advice bud. Unplugged the EGR and it ran fine. No hesitation etc. gonna take it off in the morning and completely reclean it. How far should the plunger move/open the valve?
    Mar 2013
    Warrington
    Engine : 1.9 CDTi
    Right, completely stripped and cleaned EGR. Plunger free and working. Cleaned both pipes, inlet, boost sensor next to EGR. ALso gutted new injector seal, welded up exhaust hole pre cat, replaced 2 split vac pipes. Still getting p0400 code relating to EGR flow. Is there a way of testing it. I don't want to pay £70+VAT for a new one if mine is working and its something other than the egr
    Mar 2013
    Warrington
    Engine : 1.9 CDTi
    New EGR fitted and car is now runniong brilliantly. EML hasnt come on yet so will suck it and see. Going to scotland next week so will do a regen of the DPF on the motorway and see if that clears it. May even throw in a bottle of DPF cleaner with a tank of derv and see how we get on
    Aug 2007
    North West
    Trim : SRI With a few added extras
    Engine : 1.9 CDTI 120
    Year : 06
    Glad you got it sorted mate
  1. sri cdti 150 lumpy idle/ low mpg?
    By stevesri in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2013, 20:39
  2. Irregular rear end knocking.. Possibly temperature related?
    By MCD in forum Vectra C / Signum Troubleshooting
    Last Post: 24th December 2012, 11:11
  3. lumpy 3.0 v6 cdti
    By Guss in forum Y & Z30DT Specific
    Last Post: 13th September 2011, 11:13
  4. Running VERY lumpy 1.9 cdti 150
    By kevcdti in forum Engine & Drivetrain
    Last Post: 9th June 2011, 08:33
  5. Lumpy pickup 1.9 CDTi SRi 150
    By Jon Richards in forum Vectra C / Signum Car Chat
    Last Post: 16th October 2008, 14:39
