Thread: VXR Turbo
    South Central England
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Default VXR Turbo
    I believe some places have been swapping the Vectra VXR turbo for the Insignia VXR turbo to give a minimal gain in power for a huge cost. I have read that Klasen motors have a GT3076 conversion available for the Insignia which would presumably fit the Vectra. I can't see it on their site at the moment but if anyone is considering a turbo upgrade in the future, that would be a much better option that the KKK unit.
    They also have Sachs Organic clutchs rated to 570NM (417lbft) or sinter disc versions rated to 675Nm (494lbft) though these are not direct fit for the Vectra but can be adapted.
    Any interest?
    Regular Member pogo's Avatar
    Feb 2006
    Growing old disgracefully!
    Vehicle : Vauxhall
    Trim : Astra gtc vxr
    Engine : 2.0 turbo
    What sort of difference does updated turbo give? Would it not be more laggy
    Full Member Z80's Avatar
    Apr 2008
    Noumea
    16 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    It depends : some recent Insignias now feature a dual turbo.
    However, the ECU will need a remap to benefit form the new turbo. As I can't remap, the tweakings I'm trying have limited effects (though they still have some. Getting the best from the existing hardware is actually satisfying enough).
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    The KKK units die off around 5000rpm, with boost falling rapidly. A GT3076 would be able to give more boost that the KKK unit from the moment it hit full boost to the top of your rev range. I would expect a turbo of that size in a 2.8ltr to be on full boost before 3000rpm. I am not aware of any Bi-Turbo petrols from Vx at present, so I'm not sure of the point of that comment? As with any modification you need to reprogram the car to make use of it, that is why I said for those looking to upgrade the turbo as you would have to reprogram for an Insignia VXR turbo too. I'm not sure you read the whole post there Z80.
    Apr 2008
    Noumea
    16 Post(s)
    Trim : Elegance
    Mileage : 75 000
    You're right, not for petrol, actually.
    Anyway, most turbos feature an exhaust gaz intake matching specifically the engine exhaust manifold.
    Do Insignias share some common engines with the Vectra VXR ?
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I believe so as they use the insignia turbo as a straight swap
    Apr 2008
    Noumea
    16 Post(s)
    Trim : Elegance
    Mileage : 75 000
    OK ! Like this one...
    http://autotrader.mobi/used-cars/adv...7alrmns1agbvj7
    Looks like they actually just put a similar, if not the same, 2.8 T engine in the Insignia... I don't know why I thought it was larger, actually.
    The Insignia weights 1.9 tons and has an integral 4x4 transmission, but its engines provides 355 bhp vs 280 for the Veccy... Is the turbo (and of course the mapping) the only difference on this engine ?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by Z80 View Post
    Nope, Insignia VXR is 325bhp.
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    They uprated the turbos but not enough as it is only kicking 116bhp/ltr at 325bhp, which is under what my diesel runs at the road wheels let alone the fly. With a decent turbo that thing should be up around 400bhp, after all the 2.0T runs 280bhp.
  1. Replies: 19
    Last Post: 6th September 2014, 13:54
  2. Turbo Technics Hybrid turbo details.
    By nutron in forum Diesel Engine related
    Last Post: 28th February 2011, 22:57
  3. TD04L14T turbo for Z20NET (2.0 turbo)
    By Caveman_nige in forum Parts for sale
    Last Post: 10th October 2010, 13:23
  4. Another turbo
    By mickg in forum Vectra C / Signum Car Chat
    Last Post: 29th January 2010, 10:24
  5. is it possible to change 2.0 dti turbo to 2.2dti turbo
    By EURO G in forum Engine & Drivetrain
    Last Post: 22nd October 2008, 07:35
