Thread: 1.9 cdti exhaust.. could i....
    Jan 2013
    Gloucestershire
    Trim : SRI
    Engine : 1.9 cdti
    Default 1.9 cdti exhaust.. could i....
    I've recently got myself a vectra 150 1.9cdti and looking to add a nice exhaust system to it, that doesn't cost to much and looks oem.
    I was thinking of just removing the centre section with a pre made one off ebay for £45 thats a direct replacment from the second cat to the backbox but with no middle section. First of all what kind of difference will i benefit from? I'm looking to de restrict the exhaust a little.
    But anyway then i came across this (see link below) it looks the same as the 1.9 exhaust but with the extra flange for the twin exit at the end.. im thinking if i got this then got a right hand side tail pipe.... boom? That is with your guidance is the 3.0 the same from the second cat back?
    http://www.ebay.co.uk/itm/Vectra-C-3...item43b9b075c1
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Yes, you can get these for the 2.2 which I believe go straight on (not sure on the 3.0), add another rear box and you're sorted.
    Jan 2013
    Gloucestershire
    Trim : SRI
    Engine : 1.9 cdti
    Now that is what i wanted to hear! Guessing the mounting points will already be there on the other side for the exhaust to clamp on to? Also where is the best place to get the right hand side backbox? Guessing scrap/ breakers?
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by unknownbullet View Post
    Yes, all mount points are there already.
    If you want OEM then ebay, scrappers etc will be the place to get one, or you get a custom one's made up to fit. Also, bear in mind you will need a second outlet for the 2nd pipe, as you have an SRi you can either dremmel a cut out for it, or replace the rear insert with a twin exit SRi one, or update it to a VXR one, which just clips in, like this (but require painting);
    http://www.ebay.co.uk/itm/VECTRA-C-V...item4162f3b0cc
    Regular Member Desolation91's Avatar
    Jan 2013
    Chesterfield
    Trim : Elite, Tan leather
    Engine : 1.9 CDTI
    Mileage : 106000
    is this the same for the signum?? do they use the same exhaust?
    Quote Originally Posted by Desolation91 View Post
    Nope no good for Signum buddy
    Oct 2012
    Llangollen North Wales UK
    Trim : Elegance
    Engine : 1.9cdti 120
    Mileage : 152000
    Sorry for hijacking this post, but on the same theme will the twin exhaust outlet bumper insert of a 03 Signum 2.2direct fit a 06 1.9cdti 120 Signum? cheers
  1. Will this exhaust fit to my 1.9 cdti 120?
    By baldieone in forum Styling
    Last Post: 14th September 2010, 12:58
  2. CDTi Exhaust
    By DarrenLee in forum Tuning
    Last Post: 26th March 2008, 00:06
