Thread: New brake bedding
    Regular Member sthorpe71's Avatar
    Sep 2012
    Stockton on Tees
    rolleyes New brake bedding
    Hey all, fitted new front discs and pads last week to my 2007 cdti150 and have just noticed that they only seem to be bedding in on the outer 2 thirds of the disc, both passenger and driver side identical. May be that the pads are shaped this way and will eventually bed in or maybe I f##ked up on the fitting although can't see how. Any ideas?? cheers
    South east
    If this happens, it's usually down to cheap pads that aren't machined correctly; although it can happen with decent pads as well if they just need time to bed in. If the situation is still the same after a couple of hundred miles, you'll need to change the pads before the disk gets ruined by not wearing uniformly.
    Sep 2012
    Stockton on Tees
    They were the cheaper option from europarts although I normally dont have probs with stuff from them, was a bit worried that the box said vectra 2.0dti, but assumed they must be same pads
    South east
    All 4 cylinder Vecs have the same size calipers except the Z20NET, although the issue is more likely to be about how they're manufactured rather than the size or shape.
    Sep 2012
    Stockton on Tees
    cheers, thats good to know, didnt wanna take them back out to check fitment
  2. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  3. Rear brakes bedding in?
    By AlexGSi2000 in forum Suspension, Wheels & Brakes
    Last Post: 1st August 2011, 12:42
  4. yellow brake calliper brake set
    By The Gas Man in forum Parts for sale
    Last Post: 22nd July 2010, 22:41
  5. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
