Thread: Strange Series Of Problems The Garage Cant Fix
    Nov 2012
    Birmingham
    Trim : Design (With Extras)
    Engine : 1.9 CDTI (150)
    Mileage : 99,000
    Exclamation Strange Series Of Problems The Garage Cant Fix
    My Symptoms:
    Whenever I am driving slow around town or cruising at a set speed on the motorway my car (Veccy C 150bhp) starts to jutter and feel like its misfiring and losing power for a split second, repeatedly, intermittently.
    Another symptom, when starting the car, pop the hood, there is an intermittent 2 second noise for the first 5 minutes from the engine, as if something is purging or trying (it never used to do this)
    I have a cycle of the EML and Spanner lights come on, but no fault codes.
    On the car, not necessarily to fix this issue, in the past year I have had a New Head, New Head Gasket, 2 new injectors, Cam Belt, FULL service (meaning glow plugs, all the filters, auxiliary belt, etc..), New Alternator, New EGR Valve, New Bosch Platinum Battery, oil change and a few other things.
    Any ideas of what could be causing this issue? The mechanics have no idea and have tried full diagnostics, tried pressure tests etc...
    The main issue is the cannot replicate the fault as its intermittent, seemingly its worse after a long drive, or when itís cold, mainly driving around town, if Iím driving dual carriageways itís not as bad. Some days itís much worse some days there is now problem. Driving me up the wall.
    Sorry for the essay of waffle but difficult to explain and canít find another thread like it.
    Dec 2011
    Seaham
    I am assuming all turbo related pipes have been checked for integrity?? If they are collapsing or leaking they could cause some of your issues? Also check the intercooler isnt holed.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    This sounds ike the classic case of injector no.3 faulty wiring.
    What colour are your injector plugs, yellow or blue?
    Dec 2010
    London
    6 Post(s)
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Can be EGR too, if its occurring on part throttle, that's what my old one did before I replaced/blanked the EGR.
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    What's throttle body look like is it clean?
    Nov 2012
    Birmingham
    Mileage : 99,000
    Thanks for all the advice, it turned out to be my garage lied, didnt replace my EGR and had simply cleaned it to look like new! Anyway... just for reference, what colour should the 3rd injector wiring be?
    Quote Originally Posted by merikiito View Post
    May 2011
    North Yorks
    it should be Blue i think - if its Yellow then needs replacing (that would be the plugs)
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Yep should be blue
  1. Couple of strange problems recently...
    By DannyboySRI in forum Electrical & ICE (including SatNav)
    Last Post: 24th November 2012, 10:30
  2. Is the garage section having problems?
    By Dazzy2006 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2010, 18:49
  3. garage problems! what would you do?
    By pugs,signum in forum General Chat
    Last Post: 4th June 2010, 23:05
