Thread: HID Problem
    Regular Member spikeyboi33's Avatar
    Jan 2013
    Ireland/Poland
    Vehicle : Vectra C Prefacelift.
    Trim : "Elite"
    Engine : 2.0dti
    Mileage : 130,000
    Default HID Problem
    Hi people, so yesterday i installed my 6k set into my 2003 vectra c. Now i noticed on the driver side one there's a bit of a noticable flickering going on, the other one is spot on and seems brighter too. I contacted the seller and he told me to hook the bulbs up to a 12v independent power supply to tell if its a bulb or if i need a harness relay, but i don't have anything i could use.. now i know from a passat i had before to get the hids working you would have to enable an HID and anti-shutter options using a VCDS cable. Is there something a little extra you have to do to get them working on the vectra c ?(prefacelift)
    Am i missing something?
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    One of mine is flickering too. It's either a duff bulb or ballast. Think it's bulb in my case because the ballasts are only a year old.
    newport
    is it a canbus ready kit? that would cause strobing
    but if yours is flickering i would suspect duff bulb or ballast, try swapping them round and see if the problem moves
    Regular Member Dai69's Avatar
    Nr Welshpool
    Vehicle : Vec C Estate X 2
    Engine : CDTi 150
    Year : 55&56
    Mileage : MANY
    Quote Originally Posted by taffy bhoy View Post
    Jan 2013
    Ireland/Poland
    Trim : "Elite"
    Engine : 2.0dti
    Mileage : 130,000
    Yeah i swapped out the ballasts and its still the same bulb.. So im guessing im gonna ask him for a bulb Thanks for the help guys
  1. Rear Signum Light problem problem - help
  3. Rev problem
    By mdibb2009 in forum Engine & Drivetrain
    Last Post: 29th June 2011, 08:12
  4. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
