Thread: Brake switch!
    Regular Member Lordish's Avatar
    Feb 2012
    Luton
    Default Brake switch!
    My car is lowered and my garage has a steep entrance. I must of got the wrong angle and I scraped the underside of the car and there was a bit of clunking. My check brake switch warning has come on along with the traction control ( little triangle ). They are staying on. The brakes lights are still working as normal. Anyone shine some light on this. Cheers
    Dec 2011
    Seaham
    Have you knocked an ABS wire off?
    Feb 2012
    Luton
    Not sure. I have not had time to check it out yet but I will. Thanks
    Oct 2012
    uk
    Make sure nothing serious first off but I had this when we had the last bout of snow just after chrimbo and my lights stayed on for days. After having to do an engine change ..another story!! obviously battery was disconnected but when reconnected my lights went out and has been off and working as should ever since, So try disconnecting battery overnight or a few hours
  1. Check brake light switch
    By dolf.peeters in forum Engine & Drivetrain
    Last Post: 5th July 2011, 00:55
  2. Clutch Switch & Brake Switch
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2011, 12:01
  3. cruise control brake switch
    By Al 22 dti in forum Electrical & ICE (including SatNav)
    Last Post: 16th June 2011, 18:57
  4. brake pedal switch
    By crucial in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 03:09
  5. Brake Light Switch Removal
    By Mowster in forum Electrical & ICE (including SatNav)
    Last Post: 9th October 2007, 17:01
