Thread: Cooling system
    Regular Member jamiedvvt's Avatar
    Sep 2012
    Inverclyde
    Vehicle : Vauxhall Vectra
    Trim : Sri
    Engine : 1.8 vvt
    Default Cooling system
    Been having a smell of coolant some mornings in the car when it has just been started, have checked to see if I have been loosing any coolant and can't notice any drop in the level but have noticed the level of the coolant does not really rise when car is up to temperature running, only when the car is shut off the level rises a noticeable amount and the cap hisses letting pressure out the back of the tank is this major coolant problems like head gasket or that or as simple as a faulty tank cap any help appreciated thanks
    Chelmsford
    Classic problem is a leak down the side of the radiator. The metal corrodes on the off-side, where it meets the plastic. Take a look at that before anything else. Often the cold causes the problem to get worse.
    Sep 2012
    Inverclyde
    Trim : Sri
    Engine : 1.8 vvt
    I can see where the coolant is going now it is sitting on the gearbox at the gear linkage just under the expansion bottle, have checked the hoses and they are tight no visible signs of where the leak is coming from though any one help with this
    Regular Member John Bishop's Avatar
    Oct 2010
    Have read that the expansion bottles are prone to developing hair line cracks at the back. Might need to be replaced.
    Sep 2012
    Inverclyde
    Trim : Sri
    Engine : 1.8 vvt
    Would that also make the cap hiss everytime the car is shut off after been up to temperature
    Sep 2012
    Inverclyde
    Trim : Sri
    Engine : 1.8 vvt
    If i need a new header tank will this be the right one ?
    http://www.ebay.co.uk/itm/Genuine-Va...item337e052e4f
    Sep 2012
    Inverclyde
    Trim : Sri
    Engine : 1.8 vvt
    Checked the water level in the car today and all was fine, drove about 20miles and started to smell the hot coolant smell again so pulled over and the water level in the header tank was at the top of it and spilling out the overflow on the back of the tank can anyone help with this
    Dec 2011
    Seaham
    If the header tank has a hairline crack, then the cooling system will not be building up to the required pressure. This could also cause the water to be pushed out through the crack when the water is hot, remember hot water expands.
    The hissing may even be air coming back into the overflow bottle when the water starts to cool and contract.
    Sep 2012
    Inverclyde
    Trim : Sri
    Engine : 1.8 vvt
    Put a new tank cap on there and went for a long drive on the motorway and all is well no hissing from the cap or tank hopefully that has fixed the problem
    Sep 2012
    Inverclyde
    Trim : Sri
    Engine : 1.8 vvt
    New tank cap has cured the problem
  1. Cooling system help
    By Tinks in forum South Central (ARO - Brady )
    Last Post: 11th December 2012, 21:37
  2. Z30DT - How do I bleed air from the cooling system
    By ph67 in forum Y & Z30DT Specific
    Last Post: 6th August 2012, 15:22
  3. cooling system problems
    By vmb2722 in forum Vectra C / Signum Troubleshooting
    Last Post: 20th July 2012, 19:59
  4. Cooling system
    By Tinks in forum Engine & Drivetrain
    Last Post: 21st April 2012, 10:43
  5. some probs cooling system
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2010, 18:00
vectra c radiator side plastic part leaking site:www.vectra-c.com
vauxhall vectra c 1.8 vvt radiator www.vectra-c.com
