Thread: Centre screen extras
    Jun 2012
    Castleford
    Default Centre screen extras
    Apparently theres a sequence you can do on stereo to put things like coolant temp on the centre console screen,has anyone heard, done this and does anyone know how to?
    Many thanks Matt
    Regular Member sweepcat9's Avatar
    Sep 2012
    West Yorkshire
    Simply, it's press and hold "Settings" until you hear a beep noise.
    Then press the BC button continuously to cycle through the different screens. You'll need a BID, GID or CID to see the information.
    TID - Time Information Display - Shows clock and outside temp
    BID - Board Information Display - Shows clock, outside temp and 2 lines of information
    GID - Graphic Information Display - Shows everything but only in Orange and Black (unless you change the LEDs)
    CID - Colour Information Display - Shows everything and in Colour
    12 Post(s)
    If you've got the CD70, then the following gives you loads of info about the hidden screens.
    http://www.astraownersnetwork.co.uk/...es-it-all-mean
    You'll probably have to agree to the forum rules before being able to view.
    Jun 2012
    Castleford
    Was it an optional extra or will any model with a bid cid or gid do it and by continuously you mean hold the button in?(just so im not pushing it a thousand times and sat there for ages trying)
    thanks again Matt
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    No you don't have to push it a thousand times and it only takes a minute,one push of the bc button will page to the next screen
    Regular Member Hue Jarse's Avatar
    May 2012
    Farnborough, Hampshire
    Engine : 1.8 VVT (Z18XER)
    Year : 09
    On the CD30 and BID (three line) display, nine presses of the BC button after hearing the beep will give you something like V:0 T:90 on the bottom row. The V is your speed in km/h and the T is your coolant temperature.
    Jun 2012
    Castleford
    I should mention that ive a cdc40 opera and a gid, hope this wont make any difference
    matt
    VIP-Member chrisvectra's Avatar
    Are you VXR Enough
    16 Post(s)
    Vehicle : VXR8 6.0 muscle Skoda Octavia VRS
    Trim : VXR8
    Engine : 6.0 V8
    push the main button 1st fella then push and hold the settings button till you hear a bong the use the BC button to scroll thru the menus
    Jun 2012
    Castleford
    Cool,thanks muchly people greatly appreciated
    matt
    Hanging Heaton
    26 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    How does this work on the ccr2006 with GID?
  1. Centre Screen
    By Carl83 in forum Electrical & ICE (including SatNav)
    Last Post: 7th March 2012, 17:09
  2. Problem with centre screen
    By ScotsDragon in forum Electrical & ICE (including SatNav)
    Last Post: 7th March 2011, 20:27
  3. centre screen layout
    By mat100edt in forum Electrical & ICE (including SatNav)
    Last Post: 12th December 2008, 10:29
  4. Centre screen out :0(
    By big O in forum Electrical & ICE (including SatNav)
    Last Post: 18th December 2007, 18:18
