Results 1 to 2 of 2
Thread: Low common rail pressure!
    Jan 2013
    Glasgow
    Default Low common rail pressure!
    High everyone. I have this problem since Saturday. I have Vectra1.9CDTI 120BHP which suddenly started to rev it-self, however I managed to switch the engine off. Now it only cranks but does start. There is diesel getting to injectors but no ignition. I checked on diagnostics and I there is low common rail pressure. Demanded is 50MPa and while cranking it's showing 5MPa.
    Regular Member C-Owner's Avatar
    May 2011
    South London
    If an injector is faulty it will drop fuel into the cylinder and rev its self.
    Check the injectors (leak back test) to find what ones gone faulty.
  1. Common Fuel Rail?
    By stakeknife in forum Y & Z30DT Specific
    Last Post: 25th February 2013, 21:30
  2. Where is my common rail connector?
    By holsts in forum Engine & Drivetrain
    Last Post: 22nd April 2011, 14:22
  3. Removing the common rail...
    By RobW in forum Engine & Drivetrain
    Last Post: 21st September 2010, 19:42
  4. DTUK ®CRD-T MultiChannel Common Rail+Turbo Bo
    By keith150882 in forum Diesel Engine related
    Last Post: 31st May 2010, 22:41
vectra c z30dt common rail pressure
where is the common rail for a vectra c
