Results 1 to 10 of 24
Thread: Z19DT 1.9 120 Slow to Start and lumpy APART from when CTS is disconnected
    Dec 2012
    Midlands
    Default Z19DT 1.9 120 Slow to Start and lumpy APART from when CTS is disconnected
    Would it be tooeasy to think that changing my Coolant Temperature Sensor would fix the issue?
    Usually, when cold, it cranks for a few seconds before just about firing andthen chugging for a minute or so.
    If I disconnect the CTS it fires immediately and is has a much better idle.
    Is it simply a CTS giving an iffy signal when plugged in or does disconnectingit actually do something else downstream that is actually fixing the problem?
    Thanks in advance
    Dec 2012
    Midlands
    Nothing?
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Also interested to know how this pans out...
    Oct 2012
    Llangollen North Wales UK
    Trim : Elegance
    Engine : 1.9cdti 120
    Mileage : 187 000
    Dont know if this could be related but yesterday I found that the electrical connection on an injector was broken giving a rough start up and running as tho it was on 3 cylinders now its back on four and running fine, now know why I bought my Siggy
    Regular Member any-mgzt's Avatar
    cheshire
    21 Post(s)
    Trim : basic
    Engine : Z19DT
    Disconnecting the coolant sensor makes the ECU think the temperature is lower and powers the glowplugs for longer thats why it starts easier.
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    It could well be a faulty CTS, sounds similar to a problem I once had with a petrol lump, replacing the CTS did cure the problem but they were known for failing..
    Dec 2012
    Midlands
    Ordered a new CTS, its an easy one to replace. I'll report back, probably on Saturday.
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    276 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    I had a similar problem on our high mileage vectra z19dt. Even with new CTS it was still hard to start in cool weather. In the end I altered the map for fuel during cranking and it cured the problem. Others have said a new start motor fixes it.
    Dec 2012
    Midlands
    cheers teapot :-) if the cts didn't cure it I'll try and hold out till next winter and stick a starter motor on it.
    Dec 2012
    Midlands
    changed the CTS... made no difference :-(
  1. Z19DT 1.9 120 Smoke on start up....
    By Vectra Adz in forum Engine & Drivetrain
    Last Post: 20th February 2013, 21:21
  2. Lumpy Idle when first start up
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2012, 11:11
  3. 1.9 cdti Z19DT- Cold start problems..... Please help..!!!!
    By Gavin.Dring in forum Engine & Drivetrain
    Last Post: 7th August 2012, 21:25
  4. Intermittent none start z19dt 120
    By bert3d in forum Engine & Drivetrain
    Last Post: 8th May 2012, 13:20
  5. Initial lumpy idle and slow initial throttle response?
    By Drazek in forum Engine & Drivetrain
    Last Post: 3rd January 2010, 23:48
z19dt slow start auto
z19dth slow to start
lazy starter motor z19dt
cdti starter motor slow
