Thread: Major Coolant loss pre-facelift 2.0T Edition 100!!!!!!!!
    Regular Member Nidge's Avatar
    Mar 2007
    West Yorkshire
    Default Major Coolant loss pre-facelift 2.0T Edition 100!!!!!!!!
    Hi All
    Got in the car this evening to drive home from work and the low coolant indicator was on. Before setting off I checked the level in the header tank and it was below the minimum mark. There was also a damp patch under the car.
    I drove the 10mile journey home and when I pulled into the driveway there was quite significant drip on the right underside behind about level with the rear of the front wheel arch.
    Now the car has been standing a while I've been out to check the coolant level and the header tank is near enough empty.
    I have arranged to take it to my trusted mechanic first thing in the morning but he has warned me that he has a very heavy workload and even though they maybe able to find the problem with an initial inspection they certainly won't be able to work on the car for at least a few days.
    I've been unable to find a schematic of the cooling system on-line but would anyone like to hazzard a guess at what pipework or component may have failed? Due to my dissability I'm unable to get underneath the car or jack it up and there is nothing to see while looking down into the engine bay.
    Thanks for Reading
    Nidge
    Regular Member Vectra-c-SRI's Avatar
    May 2008
    Near Glasgow
    Engine : 1.9cdti 8v (120bhp)
    Mileage : 98000
    Hole in the radiator I had the same prob for over 2yrs. I got a bottle of forte rad sealer and put the lot in fixed my prob . But am now thinkin its a slow leak .
    Feb 2012
    sheffield
    Vehicle : SIGNUM 1.9 CDTI ELITE
    Trim : ALL OPTIONS ELITE
    Engine : 1.9 CDTI 150
    Mileage : 140,000
    I would hazard a guess it is either the top/bottom radiator hose or the Radiator
    Mar 2007
    West Yorkshire
    Quote Originally Posted by Vectra-c-SRI View Post
    Thanks for the very quick reply. Unfortunately it's definitely not the radiator as the leak is about 3/4 to the rear of the engine bay and appears from behind the front right suspension arm.
    Regards
    Nidge
    South east
    The coolant bottle sometimes gets a hairline crack in the back of it that only opens up when the system is under pressure.
    Mar 2007
    West Yorkshire
    Update.
    I managed to get the car the 1/2 mile or so to the garage and the initial diagnosis is that the water pump has bit the big one.
    They won't know for sure for a day or so due to their current workload and so I've left it with them. It certainly can't be driven as by the time I got there the header tank was again nearly empty.
    I guess I'd be right in thinking this is going to be quite a major dissasembly of the engine and thus a large bill with be forthcoming. I suppose it would be advisable to have the chain(s) replaced at the same time, it's just ticked over 90,000 miles.
    Regards
    South east
    Quote Originally Posted by Nidge View Post
    No, there's a special Saab tool that costs about £35 that can be used to remove the water pump without disturbing either the timing chain or the balancer shaft chain.
    Regular Member Marcosuk's Avatar
    Fife
    I had to replace the water pump on my vec only a few months ago. I also changed the thermostat at the same time... Pre face z20net 107k...
    Regular Member dan1983's Avatar
    North London
    Quote Originally Posted by Marcosuk View Post
    Did you do it yourself and if so was it hard. I have been quoted around £200
  1. Major loss of power
    By WeDesign in forum Engine & Drivetrain
    Last Post: 17th September 2012, 13:51
  2. EML on and major loss of power
    By chrislloydie in forum Engine & Drivetrain
    Last Post: 20th October 2010, 11:09
  3. SRi 2.0T Edition 100 major issues
    By sriturbo in forum Engine & Drivetrain
    Last Post: 22nd June 2010, 12:07
  4. 1.9CDTi Major Power Loss
    By GlennM in forum Engine & Drivetrain
    Last Post: 22nd May 2010, 21:59
  5. Major loss of power
    By martinmack in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2009, 18:58
