Thread: Have I got a broken spring? Pics inside..
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    Default Have I got a broken spring? Pics inside..
    Car has started to make a weird noise, it's most noticeable if I turn the wheel while sitting still, it can almost be felt through the accelerator pedal? It's like a Grind/clunk noise.
    Just jacked it up but I can't tell for sure if its a spring or not. There are no obvious cracks or chunks missing.. And the spring looks complete as per pics..
    Is there any way to tell for sure?
    I cut a section of the upper rubber sleeve off to try and see if the spring is complete..
    Also while up in the air..
    yes 7 cracks. FFS.
    cheers!
    Regular Member Ozyboyross's Avatar
    Oct 2012
    Sprowston, Norwich
    6 Post(s)
    Trim : SRi XP
    Engine : 1.9 CDTi 150
    Mileage : 90k
    Measure the ride height both sides and see if there's a difference on one side?
    **** about the snowie! That's one reason I intend to avoid them!? Shame though coz they look awesome!
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    Drivers does look SLIGHTLY lower but i'm not sure.
    Just popped down to see my local mechanic, he looked at the springs & cant see anything wrong with them, he reckons its the top mount.
    Im still thinking spring though.
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    The spring (if like most other vauxs) should butt up against a metal tab in the bottom of the spring cup, if its not then the end is likely to of broken off. Also check higher up the spring to make sure its not broken up there.
    Oct 2012
    Sprowston, Norwich
    6 Post(s)
    Trim : SRi XP
    Mileage : 90k
    Quote Originally Posted by JJ0063 View Post
    You just wanna lower it lol tell the mrs the spring is broken and here comes the coil overs lol
    I like your style ;-)
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Quote Originally Posted by Neve'o View Post
    I agree. But look at the spring, its concentric, so if it was broken, it would still be fully around the outside. Is it on upside down?
    Norfolk
    Mileage : 69'000
    Quote Originally Posted by Das View Post
    Not sure what you mean by this? Its more than possible for the end of the spring to break off (less than half a coil for example) and still look normal until you get right in there and look, recently this happened on the girlfriends mk4 astra except there was no clonking etc.
    Plymouth
    Just got mine 2.2 Sri '03 a few weeks back and it's making a noise when turning at the front and on bumps at the back. Both on off side.
    I have a bush gone on rear upper suspension arm (banana arm) causing the noise from the rear and also for th wheel to "camber" in at the top.
    Front noise is wish bone bush.
    You won't be able to tell with a bounce etc. the only way is to get the car off the wheel you think ate the cause and with a jimmy or crow bar lift the wheel up and down and you'll feel it. Take it a decent garage and they should look at it for free and with no obligation.
    This leads nicely into my question but ill post separately as don't wanna hijack the thread.
  1. How would i know if ive got a broken spring ???
    By wardy23 in forum Suspension, Wheels & Brakes
    Last Post: 6th October 2012, 10:28
  2. Broken Spring
    By imhorwood in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2008, 21:15
  3. Broken spring
    By grumpano in forum Handling & Braking
    Last Post: 28th February 2008, 21:34
  4. Broken Spring
    By scott davies in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2007, 13:01
