Results 1 to 10 of 13
Thread: Power problems fixed!!!!!
    Feb 2012
    sheffield
    Vehicle : SIGNUM 1.9 CDTI ELITE
    Trim : ALL OPTIONS ELITE
    Engine : 1.9 CDTI 150
    Mileage : 140,000
    Default Power problems fixed!!!!!
    Hi all again,
    If you have been following my posts on my endeavors to restore the power and rectify all the problems we were having then read on......
    If you haven't been following the posts then please read them all about the stuff I have done to get this far, all the cleaning work etc was necessary to get this far!
    I had if you remember cleaned and blanked off the EGR,thoroughly cleaned the inlet manifold and throttle body,cleaned properly the boost pressure sensor (map sensor),cleaned the Turbo with the spray type cleaner, changed all the boost pipes for silicon type ones.
    All this work needed doing anyway, and it made a massive difference when done but things still weren't back to 100%, nearly there but the urgency the turbo used to have was still not quite right.
    Bear in mind I had our DPF removed 15,000 ish miles ago!
    I happened on a few posts about the DPF Cleaner type fluids that you add to your tank, after reading about how it raises the temperature and rate of which the fuel burns etc,etc, I thought I might give it a go and see if it would clear a bit more crap from the Turbo etc.....don't forget I do not have a DPF anymore and my EGR is blanked off!
    I put some 10k BOOST DPF CLEANER into my tank along with three quarters of a tank of diesel......15 miles down the motorway and what a difference I was noticing, the car was now boosting in 5th gear properly like it used to! I did 20 miles on the motorway in total and then got off and did A and B roads back home, the boost was more urgent and clean and when accelerating in fourth at 40 mph it pulled very quickly up to the next change, something I have not felt in the car since we brought it!!
    I have no Idea what is in this additive (snake oil) but I am being honest and to the point that it has restored all the power that was missing.
    Anyone add anything to this??????
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    5 Post(s)
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    what was the make of 10k cleaner that you used??
    Would you say its ok to use it if a car doesnt have a DPF?
    Feb 2012
    sheffield
    Mileage : 140,000
    Hi,
    Yes "10k BOOST DPF CLEANER" I went out looking for WYNN'S DPF cleaner but everyone including Halfords had sold out so brought the 10K BOOST stuff which I am pretty sure is basically the same stuff as WYNN'S.
    It won't hurt your car if it does not have a DPF as mine was removed 15,000 miles ago.
    Aug 2011
    Basingstoke
    5 Post(s)
    Trim : SRI
    Does it clean the whole system? i.e. manafold,throttle body ect......?
    Feb 2012
    sheffield
    Mileage : 140,000
    ermmmm....
    No what I think it did was free the turbo off, I am pretty sure the turbo lag/reluctance was due to the vanes sticking etc.
    There is no way of cleaning the throttle body and/or manifold without manually doing it yourself with cleaners etc.....read my previous posts !
    Aug 2011
    Basingstoke
    5 Post(s)
    Trim : SRI
    ok thanks for the reply
    I thougth the only way to clean the turbo vanes was to use a cleaner that you spray into the engine not an addative you add to fuel?
    Dec 2010
    London
    6 Post(s)
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    Could have unblocked cat
    Feb 2012
    sheffield
    Mileage : 140,000
    Quote Originally Posted by troutybrown View Post
    I was not aware the cat can get blocked??
    I had the DPF removed 15 k ish ago because the car went into limp mode and decided a one off payment of £200 was better than replacing it again and again etc, the car is deffo just running better and better with this stuff in the tank....lets see how it is when I put a new tank of fuel in?
    Regular Member Vectra-c-SRI's Avatar
    May 2008
    Near Glasgow
    Engine : 1.9cdti 8v (120bhp)
    Mileage : 98000
    So it doesn't matter if you have a dpf, I could still use this stuff. You say ad to the fuel? Can't I not just add 20pounds of fuel. 14litres?
    Feb 2012
    sheffield
    Mileage : 140,000
    lol....this stuff is meant for cars with a DPF
  1. Replies: 23
    Last Post: 17th November 2012, 23:49
  2. Replies: 30
    Last Post: 28th August 2012, 08:35
  3. Dibdenkid1986 problems all fixed thanks to this site!!!
    By Dibdenkid1986 in forum Introduce yourself.
    Last Post: 12th March 2012, 17:28
  4. modified hose fixed turbo lag and no power cdti
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 11th May 2010, 22:41
  5. re-post alarm problems still not fixed
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2008, 18:25
