Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Vibration through car at 2k rpm onwards, only under acceleration??
    Jun 2006
    Lake District
    Vehicle : Vauxhall Insignia
    Engine : CDTi 160
    Mileage : 53.000
    Default Vibration through car at 2k rpm onwards, only under acceleration??
    My CDTi 160 has started doing this, it feels quite bad!!
    it's not tyres or wheels as they have been checked....its in the garage i bought it from now, but they cant find anything wrong, so they are taking it to local Vauxhall dealer tomorrow for further investigation.
    My thoughts are driveshaft related, either damaged,worn or the balance weight has shifted?....or engine/gearbox mount, but surely they would have seen this??
    Anyone else heard of this?
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    Could it be the DMF on it's way out????
    Jul 2010
    sheffield
    Vehicle : Insignia vx line
    Trim : Sri vx line
    Engine : 2000
    Year : 2011
    I have a similar vibration on my car I read on insignia enthusiast that a bloke had the same problem with his.its sounds like he put something between the air filter box and bulkhead and the problem went,so today I've rolled a microfibre cloth up and stuck it between them went for a spin couldn't feel it but will not know till tomorrow when it goes on a run if its done the trick.
    Nov 2005
    Somewhere in time
    Yeah i had this....mine just made a knocking noise on start up and on gear changes as the engine moved... dab of grease on the rubber airbox mounting and it went....very common problem....not sure it would cause the a vibration through the car though....
    Jun 2006
    Lake District
    Engine : CDTi 160
    Mileage : 53.000
    Quote Originally Posted by IamtheStig View Post
    There is no noise with it at all though, non of the normal clattery racket associated with a DMF on its last legs.
    Quote Originally Posted by turbokev View Post
    It's nowt like that, the whole car shakes.
    I had that as a squeak when the car was started, found it to be the airbox mounting, and sorted it......it's not a noise i'm gaiing, the whole car shakes.
    Jul 2011
    Staffs
    Cv Joint?
    Jun 2006
    Lake District
    Engine : CDTi 160
    Mileage : 53.000
    Quote Originally Posted by thunderpantz View Post
    Cv Joint?
    That was my thinking, either that or something driveshaft related, but surely the garage would have seen that without needing to take it to the Vauxhall dealers?
    Jul 2011
    Staffs
    Accelerate when turned left and right, if the vibration gets more aggressive then CV Joints a good shout.
    leeds
    Vehicle : vectra
    Trim : sri
    Engine : 3.0 cdti
    Mileage : 55000
    mine is doing this also the car vibrates really bad under acceleration. Did it slightly for past couple of weeks, but just put lowering springs on today and its much worse now. No idea if its coincidence or not im thinkin its gotta be driveshaft related also?
    scottish region
    Engine mount ???
  1. New Vauxhalls for 2012 and onwards
    By 11mallard in forum General Motoring Chat
    Last Post: 6th May 2012, 20:36
  2. Signum 2.2 Direct - misfire?/vibration/poor acceleration
    By Fenris in forum Engine & Drivetrain
    Last Post: 31st July 2011, 23:32
  3. Compulsary ESC - 2014 onwards
    By Aidi in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2011, 11:15
  4. Wiring Harness Adaptor for 05 Onwards
    By The Doc in forum Electrical & ICE (including SatNav)
    Last Post: 20th April 2006, 00:41
https:www.vectra-c.comforumshowthread.php183361-Vibration-through-car-at-2k-rpm-onwards-only-under-accelerationpage3
insignia vibration when accelerating
zafira vibration when accelerating
astra vxr vibration when accelerating
vauxhall insignia vibration
vectra c vibration when accelerating
vauxhall astra noise when accelerating
astra h vibration when accelerating
https:www.vectra-c.comforumshowthread.php183361-Vibration-through-car-at-2k-rpm-onwards-only-under-accelerationpage2
vectra c vibration through car
vauxhall insignia shuddering
09 opel insignia vibration in engine2004 1.7 cdti astra van vibration at 2500 rpm why does vauxhall vectra engine vibratevibration through zafira pedalvectra c vibration on acceleration at set rpmzafira vibration at 2000 revsvauxhall zafira accelerator pedal vibratesastra van vibrationvauxhall insignia vibration problemsvectra cdti engine mountinsignia vibrationconstant speed 2000 rpm shaking vectra cmy astra gtc 2007 is vibrating when accelarate
