Thread: Sidelight bulbs & coolant light on dash
    Feb 2013
    Leeds
    Engine : 1900CDTi
    Default Sidelight bulbs & coolant light on dash
    Couple of things,
    firstly my sidelight/parking light bulb has gone on my passenger side headlight, I've looked in the owners manual and it says that you've to remove the headlamp to replace this bulb??
    Is this true?, n if so how is it done? Is it a garage job?
    Also, a couple of mornings when I've gone to start the car the coolant light has come on, it's been very cold -4. But during the day when the car has been left parked for hours then gone out to start the car - no warning light? Is it just because of the very cold exterior temp that's causing this?
    Oct 2007
    Reading
    Vehicle : SAAB 93 Estate, Vectra C Estate
    Trim : LINEAR SE, Elite
    Engine : Z19DTH, Z22YH
    Year : 08,08
    Not changed the sidelight bulbs but the headlight bulbs, depending on which side the battery or air box needs to be removed.
    Have you checked the coolant level when cold?
    13 Post(s)
    You can change the passenger light bulbs (excluding indicator bulb) by removing the filler tube for the wash bottle. Just unclip it from the slam panel and wiggle it out of the bottle. It mentions this in both my 2003 and 2007 handbook.
    Is your coolant slightly above the KALT/COLD marking on the side of the bottle when the engine is cold (as per the handbook info)?
    Jul 2011
    Leeds
    Vehicle : Insignia 160
    Trim : Elite Leather Light n Sight
    Engine : 2.0 16v
    Year : 2012
    Mileage : 50k
    Bulb is easy dont remove the headlamp.
    Do a search on here its been done to death
    Good Luck with your finger skin !
  1. Sidelight Bulbs
    By Tam80 in forum General Motoring Chat
    Last Post: 26th May 2012, 21:51
  2. looking new sidelight bulbs
    By VECTRA1974* in forum Bodywork & Interior
    Last Post: 4th December 2011, 18:38
  3. Which sidelight bulbs????
    By VECTRA1974* in forum Styling
    Last Post: 3rd December 2011, 19:50
  4. l.e.d sidelight bulbs
    By dilan in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2010, 10:07
  5. Vectra Blue LED dash light bulbs
    By aaruck in forum Parts for sale
    Last Post: 26th October 2007, 15:32
