Thread: Oil Pressure or oil level?
    Jun 2011
    Fife, Scotland
    Default Oil Pressure or oil level?
    The oil light came on in the screen inside the rev counter. It was yellow with an oil can above wavy lines. Is this oil level or pressure? Red light comes on and goes out with ignition.
    My car is a CDTI150
    I changed the oil+filter last week(5-30w fully synth). I put 4 litres in. I was ready to gradually top up, but after checking, the oil was way past the max level. I dropped a litre and gradually topped it up by maybe half a litre over a couple of hours. I did 20 miles and checked the oil the next day and it was way above max again.
    Ignoring this, I did 60 miles outward yesterday and the light above came on. I plugged the fault reader in and the light went out(I didn’t clear it, it just went out). RAC guy came out and can’t put his finger on it. I drove home(60 miles) with no more warning light.
    I plan to change the pressure sensor and get somebody else to do another oil and filter change. I'll look out for diesel in the oil. Coolant level appears fine. No mayo.
    Is this a warning sign of fuel pump playing up? head gasket?
    Regular Member Hue Jarse's Avatar
    May 2012
    Farnborough, Hampshire
    Engine : 1.8 VVT (Z18XER)
    Year : 09
    The yellow light is oil level warning. Oil pressure lights are always red.
    Assuming you drained as much as possible out when you done your oil change I wouldn't have thought 4 litres should have taken it "way over the max".
    The yellow light could be caused by a faulty level sensor (it's in the sump) but that wouldn't explain the variable dipstick readings. I remember seeing a thread on this forum recently where people were having trouble getting a clear dipstick indication. (Not sure it was on the 1.9 though).
    You are doing it on level ground and wiping the dipstick before taking the reading aren't you?
    Has this only happened since you did the oil change or were you having problems before?
    Jun 2011
    Fife, Scotland
    Ahh, oil level. That makes me feel a bit better. Cheers
    The oil was drained as much as possible. The car was level(not lower to the rear as would be ideal).
    I am fitting a new pressure sensor when the oil change is done(RAC guy gave me one) to rule this out.
    The oil level passes the full level and climbs up the actual dipstick by probably 10mm.
    I am checking the oil level from cold, on a flat surface and wiping the dipstick first.
    I have read about dodgy seals allowing diesel into oil and the engine overrunning. Probably more likely that I have arsed up the oil change(only done about 100 before). lol
    VIP-Member Z80's Avatar
    Apr 2008
    Noumea
    14 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Hi !
    There's no oil pressure sensor on the Vectra, only a level sensor, a temperarure sensor and a pressure switch.
    I mean it can't send any pressure value, just trigger an alert when the pressure falls under 0.3 and 0.55 bar.
    I replaced it with an Omega B pressure sensor, featuring both a switch (triggers at 0.4 bar, which matches the OEM specifications) AND a pressure sender. The pressure sender has a classical bolt-on connection, while the switch has a short length of cable with a connector that's directly compatible with the one from the Vectra. The ground connection in made through the car (and engine) body, as on the Vectra.
    It then gives a plug-and-play 100% compatible pressure switch (same threading to sump, same connector to the car) plus an additional pressure sender to feed a VDO electric oil pressure gauge. All winner mod.
    Here are the parts numbers and characteristics :
    Vectra C OEM oil pressure switch :
    OPEL 1252 572
    SAAB 90 569 684
    VAUXHALL 90569684
    GENERAL MOTORS 90569684
    Length : 50 mm
    Intérieur diamèter 1 mm
    Extérnal threading M 14 x 1,5 mm
    Threading length : 12 mm
    Spanner size : 24 mm
    Cconnections : 1
    Switching pressure : 0,3-0,55 bar
    Paint marking : brown
    Weight : 0,031 kg
    Omega B 2.5 TDi 150 bhp oil pressure sensor :
    FAE : 14010
    OPEL : 1252563 - 1252564
    GENERAL MOTORS : 90337694 - 90337695
    HELLA : 6ZL 003259-581
    VDO : 360.081/030/123 - 360.081/036/007
    Measuring range : 0-5 bar
    threading size : M14 x 1,5 mm
    Switching : 0,40 bar
    Enjoy.
    I could find one on eBay... Turkey !
    Jun 2011
    Fife, Scotland
    Cheers Z80. The Roadside mechanic gave me a pressure switch(not sensor) to fit, so I will replace it for peace of mind when my oil filter is changed.
    In my head, there is not enough oil in the engine and the low light came on, but dipstick reads too much. I am confused. The problem seems to have cleared but I will check the oil level again when I get home(driving the van today).
  1. Replies: 26
    Last Post: 14th March 2014, 01:03
  2. Oil level gsi .
    By peter-gsi in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 15:52
  3. What trim level next
    By Lee01 in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2010, 14:26
  4. oil level........
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2008, 21:27
  5. A.level
    By padawun in forum General Chat
    Last Post: 26th September 2006, 22:35
on my vectra car a light comes on showing a oil can on top of wavy lines what is it
vectra oil light came on
opel vectra c y22dtr oil pressure values
oil pressure vectra c display
vauxhall vectra c oil pressure light
oil pressure switch socket size vectra c
release vectra c 2.2 oil pressure switch
vectra c z18xer oil warning light
z18xer oil pressure switch location
vectra 2.2 oil level sensor
opel zafira 2.2 oil pressure sender where is it located
vauxhall 2.2 direct oil pressure sensor
change oil pressure sensor 2.2 diesel saab
vectra c 2.2 gts oil pressure switch
vectra showing oil pressure light and oil level light
vectra c failing oil pressure switch www.vectra-c.com
