Thread: Changing brake pads.....
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Default Changing brake pads.....
    ....is it the same process as the Vectra to replace them or have Vauxhall made it complicated??
    South east
    Seems to be the same as the Vectra-C, i.e. no rewind tool needed for the front calipers, (you do need one for the rears, but I've heard talk you need left and right handed threads, one for each side, ala Ford Mondeo estate), and you just undo the slide bolts and pull the caliper apart.
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    Done mine all round the other week.....pads sit inside a metal clip which fits in the caliper so make sure this comes with the pads as this is what causes the rears to stick and bind(copper grease a good idea)..
    My rear calipers both wound back in clockwise.....
    slough
    if you have the electronic parking brake i hear you have to re set the cars electronics using a computer after changing rear pads ???????
    Nov 2005
    Somewhere in time
    The parking brakes are still pulled on by cables......these go to the motor which is in the n/s part of the boot....looking from underneath it looks just like the Vectra..
    Birmingham
    I do have the electronic handbrake button, does that mean I cant DIY the brakes, is it a dealer job?? What if I just leave the handbrake off??
    Nov 2005
    Somewhere in time
    Leave the handbrake off and it's the same as the Veccy....cables stay attached to the caliper ....
  1. Changing rear brake pads
    By Sean-2.2Direct in forum Suspension, Wheels & Brakes
    Last Post: 21st January 2009, 14:14
  2. Changing brake pads
    Last Post: 26th November 2008, 17:58
  3. Changing brake pads
    By dutluk2001 in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2008, 21:06
are the break pads for a vectra the same as an insinia
changing brake pads on Vauxhall insignia with electronic handbrake
insignia rear pad change
vauxhall insignia rear brake change handbrake on or off
vauxhall insignia rear brake problems
how to change brake pads on a vauxhall insignia
