Results 1 to 3 of 3
Thread: Problem with cruise control on Vectra 2005 cdti v6
    Mar 2013
    west Midlands
    Vehicle : Vectra estate
    Trim : elete
    Engine : 3000
    Smile Problem with cruise control on Vectra 2005 cdti v6
    Hello every one just joined & need some help or guidance on how to fix at reasonable cost a problem with the cruise control ie it has just stopped working. Vauxhall put it on the computer & said it was the switch but when the went to fit new switch said it was not the switch after all and the control module needed replacing at cost of £490 + Vat fitted. the car is only worth about £1,500 so told them at that price, no thanks.
    Has any one got any information on where I can get a Module at a reasonable price & how to fit it. I worked in motor trade 30 years ago so I'am not completely useless at such things but would not like to attempt it without some guidance as dealer said it needs to be reprogrammed when fitted and I obviously don't have the gear to do that.
    Any help would be much appreciated.
    Altham.
    Full Member Robsey's Avatar
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    Usual faults on these are
    Faulty switch on the indicator stalk
    or
    Weak clutch pedal return spring.
    test your clutch spring first, by driving and holding the pedal up with your left foot.
    If the cruise control now works, then it is the clutch spring that needs replacing.
    The indicator stalk could be either a faulty stalk or dirty contact faces.
    not that common to have to replace the entire CIM, just for cruise control..
    there would normally be other items affected too.
    Agreed, this sounds like a failed CIM
    The main issue is that both keys (and any others you have) need to be reprogrammed to the new CIM
    What you could do is look at a third party warranty
    I have just purchased the AA Repair Cover
    This has a 15 day waiting period, then you can commence a new claim
    Note you will have to call out the AA first for them to confirm the fault
    However as above expect other faults to appear with a faulty CIM
    Next, you will need to take the car to a different VX dealership
    Contact the VX dealership in advance to see if they have an account with the AA, then all you need to pay is the warranty policy excess (currently £35)
  1. Vectra C 2005 CDTi 1.9 8v - Starting Problem
    By aaronfenwick in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2012, 12:44
  2. 05 Vectra CDTi - Cruise control problem
    By gmc in forum Engine & Drivetrain
    Last Post: 9th September 2010, 21:40
  3. Cruise Control Problem
    By gsi.vxr in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2010, 13:16
  4. Vectra 1.9 CDTI 150 2005, Intermitten Problem
    By Vaux-Man-G in forum Vectra C / Signum Troubleshooting
    Last Post: 24th April 2008, 11:53
  5. Yet Another Cruise Control Problem!!
    By jaxouk in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2008, 19:22
