Likes Likes:  1
Thread: Vectra C Ignition Switch Help Please!!
    Oct 2012
    Mauchline
    Default Vectra C Ignition Switch Help Please!!
    I have bin having an annoying problem for months now with my car when i take my key out the ignition the cd player stays on and you have to push the big round button to turn it off also the warning buzzer comes on when i open the door as if my headlights are still on and also the central locking does not work i was told this could all be related to the ignition switch as it could be faulty and the ignition thinks the key is still in therfore causing these problems. It would really be appreciated if some one could shed light on this and has anyone ever replaced the ognition switch as i cant find any info on it atall. I have had all the plastics behind the steering wheel tryin to find it but had no joy. Thanks
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Could be ignition barrel worn, could also be a CIM fault.
    Would help to know the model, stereo type, mileage/age, etc. (Helps people get an idea of the general vehicle condition).
    Have you tried a few squirts of WD or similar deep into the lock mech ?
    Oct 2012
    Mauchline
    Its a 2008 sri 54000 miles and the stero is a cd 30 a think al try the wd 40 in the morning its frustrating as hell.
    Regular Member Robsey's Avatar
    North East Cheshire
    26 Post(s)
    Trim : Energy
    Mileage : 150,000
    First thing to try is to pull the battery for 15 to 30 minutes.
    Force a module reboot.
    It could well be a faulty ignition key barrel fault, or a CIM fault.. but it could also be a module hiccup.
    These happen all too easily on Vectra-C's.
    You will struggle to dismantle the ignition barrel out of the back of the CIM module.
    The plastic casings are a ****** to separate.
    Once you have done this, there is a 2 pin pick-up ring and a 7 pin ignition barrel connector to unplug.
    Rebuilding is a bit tricky, as you will need to fit the clock spring correctly and may also need to recallibrate the steering angle etc..after refitting the CIM module.
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    236 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Is your stereo set to work with ignition logic, or via the on off button ? Set it to off if having turned it off, you want it to stay off, unless that is you have other ignition switching problems.
    Good luck fella
    OOPS - Clashed with Robsey , ignore me and PAY ATTENTION to "him" LOL
    Oct 2012
    Mauchline
    Well tried the wd40 and tried disconnecting the battery still no luck.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    Same problem as I'm having
    birmingham
    Engine : 3200
    Hi did you get to the bottom of the problem? I'm getting the same problem, remove key from ignition and still getting the ding ding ding noise, also CD player stays on, interiour lights don't come on, Central locking don't work on the key have to use the door locks
    basically the ignition thinks the key is still in and we get the ding ding ding noise because it thinks your gonna leave your keys behind lol
    pain in the ass ain't it ggrrrrrrr :-/
    Nov 2014
    Mine is doing a similar thing, seems to tally with the first drive on a cold morning. My thoughts are that a relay is sticking, is there a relay under the bonnet switched by key position 2?
    Regular Member tbclose1992's Avatar
    Aug 2012
    Victoria
    Trim : CDXi (GSi or GTS)
    Engine : Z32SE
    Mileage : 205,000km
    Has anyone had any success with rectifying this fault? My 03 GSi in Australia has done exactly the same thing and fails to switch everything off 80% of the time unless I pry on the key entry slot and jiggle it. Central locking won't work whenever this happens too and I'm greeted by the immobilizer every time I go to start the car. I'm not mad after 370,000km but the more I know about the issue the better when I get it diagnosed.
    Sent from my LYA-L09 using Tapatalk
  1. Vectra C Ignition Switch Help !!
    By Robbiew.90 in forum Electrical & ICE (including SatNav)
    Last Post: 11th March 2013, 22:25
  2. Ignition Switch replacement
    By magpie27 in forum Electrical & ICE (including SatNav)
    Last Post: 16th April 2009, 17:13
  3. vectra 2.0 dti ignition
    By raymond1711 in forum Engine & Drivetrain
    Last Post: 26th February 2009, 23:20
  4. Ignition Switch Wire
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 24th October 2008, 17:05
  5. Ignition switch wiring please!
    By blue estate in forum Electrical & ICE (including SatNav)
    Last Post: 30th August 2008, 00:05
vectra c ignition switch
vectra c ig
corsa c ignition switch problems
vectra c ignition of
vectra c ignition
remove ignition barrel vectra c
how to remove ignition from vectra c
vectra c ignition barrel loose
vectra c ignition barrel removal
vectra c ignition module
7 pin ignition switch vectra c
fit ignition switch vectra 3.2 v6
vectra c ignition switch problem
