Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: Car lumpy and still smokey after new glow plugs
    Regular Member SEANYboi's Avatar
    Dec 2012
    Bourne end,high Wycombe
    5 Post(s)
    Vehicle : Vauxhall vectra
    Trim : Sti nav
    Engine : Cdti 150
    Year : 55
    Mileage : 96000
    Default Car lumpy and still smokey after new glow plugs
    Replaced glow plugs Saturday and car seems worse, it's a bit lumpy on start up and a bit smokey,also seems a little bit louder.
    Regular Member dartraxx's Avatar
    Jan 2013
    gwynedd
    Vehicle : 1.9cdti sri xp2 nav
    Trim : xp2 vxr styling
    Mileage : 68K
    What were the make of the plugs you fitted pal?
    Jan 2012
    Gloucestershire
    You say still smokey...what were the original symptoms that made you change your glow plugs? Presumably poor starting, but only from cold? Any other problems?
    Dec 2012
    5 Post(s)
    Trim : Sti nav
    Engine : Cdti 150
    Year : 55
    Mileage : 96000
    Bosch plugs.
    And yes poor starting and had the car with spanner light on, which went out after a few miles.
    before the poor starting and light being on, the car was fine.
    the light doesn't come on now
    Dec 2012
    5 Post(s)
    Trim : Sti nav
    Engine : Cdti 150
    Year : 55
    Mileage : 96000
    Also with the old plugs in, it's wasn't lumpy on start up
    Jan 2013
    gwynedd
    Mileage : 68K
    BOSCH tend too be a good buy! does the glow plug light on dash go out after couple of secs on first start, in the morning?
    Dec 2012
    5 Post(s)
    Trim : Sti nav
    Engine : Cdti 150
    Year : 55
    Mileage : 96000
    Yeah got no prob with the light now
    Jan 2012
    Gloucestershire
    If you have access to a code reader you may be able to read the stored fault codes, even if the eml has gone for now.
    Jan 2013
    gwynedd
    Mileage : 68K
    on start up, does it feels like its misfiring/lumpy as you say. Then its running fine after a min or so? correct pal? if so take the plugs out, theres a way of testing them to see them glow and if there instantly or delaying there glow time! take each plug to the positive side of the battery touching the positive with the top connection end not the glow tip end, hold it there to see how fast it glows up, test each one and see if theres any difference between them all! dont hold them there too long only until theyve glowed, if delayed in heat up time and not instantly, then the are faulty plugs!
    Dec 2012
    5 Post(s)
    Trim : Sti nav
    Engine : Cdti 150
    Year : 55
    Mileage : 96000
    Quote Originally Posted by dartraxx View Post
    Cheers mate. Bit lumpy/rough idle to start with then stops after about a min.
    Will check them all next time I get a chance
  1. 2.0DTI Lumpy & smokey in the morning, and drinking oil
    By cyberbobdude in forum Engine & Drivetrain
    Last Post: 27th October 2012, 23:11
  2. Is this a glow plugs gone
    By Pjuk in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd March 2012, 16:20
  3. Glow plugs
    Last Post: 25th December 2010, 12:02
  4. glow plugs
    By bigcarp1953 in forum Engine & Drivetrain
    Last Post: 13th December 2010, 11:28
  5. glow plug relay and glow plugs
    By bobk1 in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 17:02
