Thread: revs
    Feb 2013
    liverpool
    Vehicle : vectra estate
    Trim : club
    Engine : 2.0 dti
    Default revs
    hi guys,my 2.0 dti estate 05 reg,is reving up and down when idling,this causes fumes to enter car as the exhaust is under rear seats and not out the back.it also sometimes misses the beat when driving,though not all the time.no dashboard lights showing (fault lights),appreciate any advice,thanks
    Feb 2012
    sheffield
    Vehicle : SIGNUM 1.9 CDTI ELITE
    Trim : ALL OPTIONS ELITE
    Engine : 1.9 CDTI 150
    Mileage : 140,000
    Hi,
    Feb 2012
    sheffield
    Mileage : 140,000
    ...Try cleaning the throttle body
    Feb 2013
    liverpool
    Trim : club
    Engine : 2.0 dti
    will do,thanks for the info
    Feb 2013
    liverpool
    Trim : club
    Engine : 2.0 dti
    how do u blank an egr off ?and do you have to get the car mapped,appreciate any help guys
    Regular Member dartraxx's Avatar
    Jan 2013
    gwynedd
    Vehicle : 1.9cdti sri xp2 nav
    Trim : xp2 vxr styling
    Mileage : 68K
    Fiat type blanking plate off ebay only few pounds. Yes EGR has to be mapped out pal
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    278 Post(s)
    Trim : Design+
    Mileage : 101000
    Quote Originally Posted by razrtour View Post
    On the DTI, I don't think there is a suitable blanking plate - that only applies to CDTI engines.
    Not sure about the Vec-C DTI, but the Vec-B and Astra 2.0 DTIs would go into limp mode if the EGR valve wiring or vacuum pipes were disconnected.
    Its easy to disable egr by mapping on most 2.0 dti's (which use an EDC15M ECU) but not the vec-C as it has a PSG16 ecu/pump control unit. As far as I know, only EDS have the equipment and experience to do these.
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    u can also do tje psg16 with a mdi unit matey get the ori open it up with whatever software u use then can delete from there but must stress it only works with a mdi unit
    woodbridge, suffolk
    278 Post(s)
    Trim : Design+
    Mileage : 101000
    Quote Originally Posted by paulvectrac View Post
    Good to know, but a bit out of my price range it would appear! Do you have one? Also where do you find the ori? guessing they must be on the tech2/mdi flash cards??
  1. 3k revs and thats it.....
    By johnaw in forum Engine & Drivetrain
    Last Post: 11th January 2012, 18:44
  2. revs
    By steelee in forum Vectra C / Signum Troubleshooting
    Last Post: 17th November 2011, 23:02
  3. All revs no go!
    By Princess D in forum Engine & Drivetrain
    Last Post: 2nd November 2010, 00:11
  4. Sticky revs
    By inverkip1 in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2009, 11:24
