Results 1 to 10 of 14
Thread: Pulsing Headlights?
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Default Pulsing Headlights?
    Hi Peeps
    Can you guys offer any advice?
    I have noticed, only recently that my headlights have started to pulse/blink, they dont go out just dim for a split second, then 20-30 seconds later, does it again. Not noticed if it only does it when the engine is hot/cold yet.
    No warning lamps, everything works fine and starts perfectly well.
    Anything to worry about or start saving for?
    cheers peeps.
    DV
    Regular Member pompey-pimp's Avatar
    Nov 2009
    Fareham Hampshire
    Vehicle : BMW 520D Touring
    Trim : M Sport Business
    Engine : 2.0 d
    Year : 2010
    Have you changed them to LED's? It will be the OBC sending a small amount of current to each lamp to check if it is ok. LED's require less current to run and will therefore illuminate momentarily.
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Hey Pompey...
    No mate, all standard lamps. NO LEDS.
    thanks for the response though.
    DV
    Regular Member STICKY3.2's Avatar
    Jul 2010
    Hertfordshire
    Does this happen at idle or when you are driving?
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Hey Sticky,
    Defo on idle.. and at very low speeds, such as a crawl. to be honest not noticed at 30, hard to see.
    Next time im out, ill check whether having the AC on/off makes a difference.
    cheers
    DV
    Dec 2010
    London
    5 Post(s)
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    Power steering pump is electric and draws up to 60 amps so lights can flicker. Mine did on standard bulbs but since 35w Hids fitted this has stopped.
    Jul 2010
    Hertfordshire
    Quote Originally Posted by dv8 View Post
    Hey Sticky,
    cheers
    DV
    You beat me to it, I was going to suggest trying it with the A/C off and see what happened
    ijk571
    Guest
    My old mondeo used to do it 2-3 times a second and it was all the electrics, alternator perhaps?
    Nov 2009
    newcastle
    2 possibles for me. do the £5 earth mod in the how2 section to ensure earth ok. then Get alternator checked for output my last vectra was kicking out 11-12v under load so not the 13-14 it should. Got the bearing and diode pack refurbed for £40 a d good as new.
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Hi Geordieic
    Yes mate, earth mod done many moons ago, a simple one for me so gave it a go. Ill grab the multimeter and check to see what voltage the batt sits at and is running at later to see if the alternator is struggling...
    'The hearse' as she is affectionately known, being black and an estate doesn't get used as much as she should or used to, but this is only happened recently.
    cheers Peeps.
    DV
  1. Pulsing boost prob NOT fixed!
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 21st February 2012, 22:24
  2. HELP!!! Engine Pulsing and wont go over 4k revs!!
    By sub2199 in forum Engine & Drivetrain
    Last Post: 6th December 2010, 10:26
  3. Pulsing boost
    By Gazza36 in forum Engine & Drivetrain
    Last Post: 29th April 2010, 17:58
  4. LED Flashing / pulsing
    Last Post: 30th October 2009, 22:56
  5. Pulsing Idle Then Spanner Light
    By R13hard in forum Engine & Drivetrain
    Last Post: 5th March 2009, 22:49
