Thread: gear re-alignment or fluid level?
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    5 Post(s)
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default gear re-alignment or fluid level?
    Hi guys,
    I have a F40 gearbox in my 06 veccy c and have the usual notchy gear change(espcially from 2nd to 3rd) I know that they are known for being notchy and there are 2 ways of making things smoother
    1)drain off the oil and refill to suggested level
    or
    2)re-align the gears(via the how2 on here)
    My gearbox is really notchy when i change between 2nd up to 3rd but what i have noticed is that if i change gear when turning and sometimes going up/down hill gear change is silky smooth
    Does this sound like fluid related notchyness(the fluid moving around in the box causing the occasional smooth change)
    What do you guys thinks?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Try the realignment first since its free and if its still no better try changing the gear oil
    South east
    Realigning the selector rods and changing the oil level are for two subtly different set of symptoms. Do the oil change if you get a crunch between 1st and 2nd when cold, and 2nd and rd when warm. Do the rods if the gearlever feels too tight and doesn't want to move.
    Aug 2011
    Basingstoke
    5 Post(s)
    Trim : SRI
    Did the oil change and for the forst 5 mins of driving its felt a heck of alot better but now its back to the way it was
  1. Washer Fluid level sensor???
    By Ian S100 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2016, 00:15
  2. how to disable low washer fluid level
    By mrk in forum Electrical & ICE (including SatNav)
    Last Post: 8th June 2012, 13:54
  3. clutch fluid level? how do i check it?
    By renton608 in forum Engine & Drivetrain
    Last Post: 8th February 2011, 19:25
  4. PAS Fluid level
    By Rob_the_Scot in forum Suspension, Wheels & Brakes
    Last Post: 8th March 2007, 00:00
