Page 1 of 15 12311 ... LastLast
Results 1 to 10 of 143
Thread: caterman box
    Regular Member scott_150cdtisri's Avatar
    Jan 2006
    Crewe
    Default caterman box
    hi chaps just a quick visit, what are these caterman boxes i see people talking about are they as good as the cr1, where do you get them and more importantly how much are they lol. whats the power increase like did i read they are much cheaper than the cr1 but do just as good
    cheers
    scott
    Here, there and every where!
    They are basically a cr1 but much cheaper. They are around £65 delivered and will give you around 185bhp+
    LINK HERE
    Jan 2006
    Crewe
    i cant read german!! are they adjustable like the cr1, did you have any problems with it? these seem a good alternative as the price is cheaper
    Not adjustable m8, just plug in and drive
    I've not had any problems and i've had 2 of them, running one on my signum now. I only know of 1 person that has had problems with one but it might not have been the box at fault.
    Jan 2006
    Crewe
    well unfortunately i have to go to work now but thanks for the info and hopefully when i get back all you good members would have left me lots of views about it! hint hint!
    cheers
    Regular Member Steve CDTi's Avatar
    Wirral
    Hi Scott,
    Just fitted one of these so can comment -
    Ordered off ebay - you'll find the link here easily enough. Don't foget to specify your model, year, engine size and version etc when ordering - they will email you anyway if you don't (as I didn't !!) - however adds to the time. Once confirmed arrived quickly however.
    Fitting was relatively easy - just unplug the connector from the common rail on top of the engine (this was actually the hard part as the yellow clip underneath needs to be unclipped first.
    Fitting the leads the right way round proved to be somewhat trial and error however - the male/female connectors can only go one way of course, however the plugs at both ends can be rotated 180 degrees, and the box will not work unless correct. It took me three goes to get it to work - I followed the pictures on this site however they did not work for me - the plug attached to the common rail must be the right way round - which was opposite to the pic I used - then it worked fine.
    The symptoms of it the wrong way round are idle at 1500 rpm abd will not rev. This will also throw a spanner warning light which goes out when started up. Obviously the ECU picked up the rail not working correctly. Getting it the right way round seems to be a bit trial and error - just wondering if the boxes are wired consistently.
    Once installed correctly and fired up to check it all works properly - use cable ties to secure the box and leads to a convenient position.
    The box does make a difference - not earth shattering - however gives a bit more low down power, and more torque when the turbo kicks in.
    Definitely a worthwhile investment I would say, generally the car is more driveable and gives you more of a kick when required. Still too early to say re MPG as I'm still on the same tankfull of diesel.
    Don't forget to notify your insurer if you go ahead.................
    Steve
    Jan 2006
    Crewe
    right im almost sold in getting one of these, just wondered about ahem telling the insurance company. is it likely to affect it much has everyone declared them and do you just simply tell them you have a tuning box on? i`ve read a lot about people asking about reliablity surly its no different than back in the old days when people used to put bigger carbs on did they declare them!
    Regular Member ballogie's Avatar
    Scotland
    Mine was a doddle to fit (5 mins max, well ten minutes cuase it took me 5 to find a hex to remove the engine cover).
    Definite difference in performance. Well worth the £65
    OBE due to Caterman for the find, I'll send Tony a text
    Oct 2006
    Yorkshire
    Default box
    ..deffo worth fitting, it turns a 150bhp sri from a "somewhat sporty" diesel into a road muncher.
    Its quite hard to believe how much harder the car pulls with the box on...i regularly overtake in 5th gear now thinking I am in 3rd!
    They make the car much more driveable in my opinion and reduce the "lurch" from the standard engine when the turbo kicks it to a constant strong torquey pull right past 4000 rpm.
    Definateley get one - at 65 quid they are cheap as chips. They are also quite technical - doing a babelfish translation on the ebayers websites suggests they monitor the engine temp to ensure that the temp has reached a minimum before applying full power.
    I have declared mine to my insurer. Declared it as a tuning box designed to improve MPG. They have added it to my policy at zero increase in premium
    Regular Member garner's Avatar
    Bennyk did they ask you if it increased bhp? Who do you insure with?
    garner
  1. Caterman Box
    By PeteRs in forum Parts for sale
    Last Post: 14th May 2008, 14:08
  2. caterman box
    By alijlacy in forum Diesel Engine related
    Last Post: 20th April 2008, 16:41
  3. caterman Box
    By carport in forum Parts for sale
    Last Post: 24th February 2008, 16:06
  4. Was it the Caterman??
    By stoneyVectra in forum Diesel Engine related
    Last Post: 8th November 2007, 11:23
  5. Caterman Special/Caterman box...
    By MyLittleEgg in forum Diesel Engine related
    Last Post: 24th September 2007, 18:22
