Results 1 to 10 of 19
Thread: Help! Fitting bilstein shocks
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    Default Help! Fitting bilstein shocks
    Hi all, in the middle of changing the shocks on my vectra to bilstein b6's I've got the first shock off the car, removed spring etc. but when I've went to put everything on the bilsteins the orange foam bump stop thing doesn't go on the bilstein properly as the shaft on the bilstein is much thicker than standard.
    Am I supposed to bore the bump stop out to make it fit or is this bot right?
    Please help, sat in the carpark with my car in bits and it's freezing!
    Ely, Cambridgeshire
    63 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Doesn't need the bump stops. The Bilsteins have them built in inside them.
    Engine : Z20NET
    Thanks Ian!
    Engine : Z20NET
    Ok, next question, re-assembled everything and now i have a strange knocking sound, any ideas?
    Engine : Z20NET
    Still haven't solved this, sound's loke something is seriously loose but on checking my work nothing appears to be, it sounds horrendous, only pulled it out the car park and put it straight back in for fear of something happening
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Have you tightened the drop links up tight?
    Regular Member Dai69's Avatar
    Nr Welshpool
    Vehicle : Vec C Estate X 2
    Engine : CDTi 150
    Year : 55&56
    Mileage : MANY
    Did you replace the top strut mounts and bearings at the same time? I had a similar problem when I replaced my struts springs etc. Although the top mounts and bearings all seemed okay when i was changing everything I had a new knock when I'd put everything back together, so bad at times that I thought the front end was falling off. This turned out to be the top mounts.
    Hope you get it sorted soon
    Engine : Z20NET
    Drop link is done up nice and tight, one thing I did worry about was torqing the bolt in the strut as all of the methods listed in the how to cannot be used with a torque wrench, so i just did it up nice and tight and made sure it matched the other side
    Hmm, how much are the top mounts and bearings, do we have part numbers? Weird how it wasn't doing it before!
    But yes the sound does resemble the front end wanting to fall off lol!
    Nr Welshpool
    Engine : CDTi 150
    Year : 55&56
    Mileage : MANY
    Huge selection and it's probably worth shopping around but here is an example off ebay ....
    http://www.ebay.co.uk/itm/VAUXHALL-V...item337e9029a4
    Engine : Z20NET
    They really need to be done quick, my local euro carparts have got them in Part No.: 609720260 for £21.30 (obviously I need 2)
  1. Bilstein B4 shocks
    By shb1988 in forum Handling & Braking
    Last Post: 19th May 2013, 02:03
  2. Bilstein B6 Shocks
    By pipamish in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2012, 08:14
  3. does anyone have Bilstein B6 shocks?
    By Alex the Russian in forum Handling & Braking
    Last Post: 1st August 2011, 09:00
  4. Bilstein B6 OR B8 shocks
    By johnnyboy1985 in forum Handling & Braking
    Last Post: 7th July 2011, 19:13
  5. Bilstein B4 shocks
    By Dwabo in forum Handling & Braking
    Last Post: 24th January 2008, 23:39
fitting bilstein shocks
