Thread: Fuel Gauge - Calibration ?
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    234 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Default Fuel Gauge - Calibration ?
    Hi guys.
    The fuel gauge on my car shows 3/4 full when it is brimming at the filler cap.
    Is this something caused by a sensor problem or a faulty gauge, or can it just be re-calibrated with something like Tech2 or Vauxcom ?
    Regular Member ThatAudioBloke's Avatar
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    Do a gauge test on *com and see if it goes all the way to the max. If it doesn't, then it's likely that either the needle has been off and put back incorrectly or there's an issue with the gauge. If it does, then you've probably got an issue with the fuel level sender.
    May 2012
    234 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Thanks for that, if the gauge only goes to 3/4 with the tester, is there an adjustment for calibrating it ?
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    I think it maybe possible to re adjust.
    if not just bend the float in tank lol
    it could be that the level sensor just isn't reading correctly.
    or resistance somewhere
    its only a variable resistor
    May 2012
    234 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Hi matey, I thought it was probably only a VR, just wasn't sure if it existed and if so, where it is .
    Bending the float in the tank sounds pretty hit and miss LOL, plus, how would you get at it to bend it ?
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    The resistor is built into part of the tank pump.
    it was more a tongue in cheek thing how ever I have heard its worked on corsas from vx tech
    getting to float involves lifting rear seat and undo the top of pump.
    sounds daft but have you tried filling it until you see fuel in the filler neck?
    May 2012
    234 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Quote Originally Posted by Critch View Post
    Oh **** I had hoped that Vx might have fitted a fine tune VR to the unit, but I guess that in order to do that, they would have needed to fill the tank, fat chance of that I guess.
    Yes, have filled fuel to the brim and it is only showing 3/4 everytime. I guess it's something I will just have to live with, had just hoped there would have been a "fine tune" LOL
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Ill have play tomorrow and let you know
    you can do a guage test.
    May 2012
    234 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Cheers matey, gauge test "lined up" for tomorrow fella
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    No dramas mate
  1. Fuel Gauge
    By tatters40 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th January 2013, 14:33
  2. Fuel Gauge
    By don23 in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2011, 23:09
  3. fuel gauge
    By vauxie in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2010, 21:00
  4. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
  5. Replies: 2
    Last Post: 15th September 2008, 23:18
opel vivaro fuel calibration
vauxhall vivaro fuel gauge calibration
