Thread: No power?
    Nov 2012
    Glasgow
    Default No power?
    Hi got in the car today started no prob went to pull away and it was really slow you could walk quicker... ther was a car with a spanner in the middle of it showing on the dash,so stop the car left it for a while then started it again no prob drove the way it should anyone had this happen to them ? wat would have cost this?
    Regular Member ThatAudioBloke's Avatar
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    Petrol or diesel? Get the codes read but if it's a diesel possibly something to do with the EGR valve?
    Regular Member Vectra-c-SRI's Avatar
    May 2008
    Near Glasgow
    Engine : 1.9cdti 8v (120bhp)
    Mileage : 98000
    Had this prob on mine few times I found it was my egr. How I found it was that was I disconnected the power going to it and drove the car for about a mile.it drove like new. So pluged it back in and back to slow again so gave it 10min to get car temp up and gave it a gocod bootin on motorway. It's be 3wks now since loss of power... Mine was reallllly slow until turbo kicked in
    Nov 2012
    Glasgow
    Quote Originally Posted by BoostPuppy View Post
    Its 1.8 petrol..m8
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    Hmm... not sure then, do the petrol ones have an EGR setup? I drink from the black pump so I don't think I'll be much use to you.
    If it put the car/spanner light on, it should have stored a fault code so it's definitely worth getting them read, I'm sure there'll be someone close with the appropriate hardware who can do it for you...
    Feb 2011
    cheshire
    i use to get that regular on my veccy b, it was always the throttle body needed cleaning,but not had problem with veccy c 1.8
    Jan 2008
    South Wales
    Best to get the codes read. Be careful if buying a code reader, a standard EOBD / OBD-II code reader wont read the 'car & spanner' light fault codes. You need something to go in on Vauxhall's language to read these codes. You can get PC interfaces & software for around £70- cheaper than VX quoted me for a scan.
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Signum Sluggish low power, Limp mode at high power.
    By Bigg943 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th June 2011, 18:55
  3. Signum Sluggish low power, Limp mode at high power.
    Last Post: 5th June 2011, 11:30
  4. Replies: 11
    Last Post: 7th January 2010, 17:50
  5. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
