Results 1 to 10 of 13
Thread: Cooling Error codes despite changing temperature sensor - Anyone got a relay diagram?
    Jun 2012
    Milton Keynes
    Default Cooling Error codes despite changing temperature sensor - Anyone got a relay diagram?
    Hi, Hope you can help. I have error P0482 - Fan Control 3 Circuit Malfunction appear on my '04 2.2 Petrol (z22se). The cooling fan had not been running and the engine would run hot if stuck in traffic. I replaced the coolant temperature sensor that is located at the thermostat housing and the cooling fan now runs, the engine no longer gets so hot but the error is still present. I have checked fuses 35 and 36 for the cooling system and they are fine.
    My next thoughts are it must be one of the relays or an issue with a fan rotation sensor on the fan itself. Or maybe even the thermostat is faulty and the temperature sensor is throwing a fit? Any ideas?
    The car runs perfectly and returns good mpg/performance so I'm alittle confused with what could be wrong.
    If it helps I was also getting a warning regarding the oil pressure switch, which after replacing has now not appeared again.
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Do you have access to tech2/opcom?
    Jun 2012
    Milton Keynes
    I have opcom
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    have a look at the fans to make sure not seized ,check fuses ,
    sounds like control unit on fan housing could be faulty
    Administrator plasma's Avatar
    On the Forum
    548 Post(s)
    Engine : 150
    Mileage : 74000
    On the Forum
    548 Post(s)
    Engine : 150
    Mileage : 74000
    could be the wiring either to the fan itself or on one of the multiblock connectors, had this problem on kmans car... Removed the connectors gave them a cleanup (switch contact cleaner will do) and then reconnect.
    think theres 2 fans but they run on a combination of 3 different settings
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by solamanda View Post
    Has that one got the resistor for fan speed 3 underneath the radiator front bumper area, it corrodes through and stops the high speed fan cutting in.
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    With opcom you'll be able to activate the various speeds of the fan.
    Jun 2012
    Milton Keynes
    Sounds like a good idea. If I can't activate the (3?) speeds after clean connectors then its new control unit time. I'll have a go with opcom.
    milton keynes
    As Dean said. Mine was giving me random issues. I sprayed wd40 on the engine ecu contacts and cleaned them with a cotton bud and my fan issues never came back. I had tried to replace fans and wiring previously.
  1. Error P0425 Exhaust Gas Temperature Sensor High Voltage
    By dieselman in forum Engine & Drivetrain
    Last Post: 29th April 2013, 22:30
  2. 3.2 error codes help please
    By gibsonk in forum Engine & Drivetrain
    Last Post: 28th January 2012, 13:03
  3. Changing dual cooling fans
    By Jonsey in forum Engine & Drivetrain
    Last Post: 4th July 2011, 21:59
  4. Fuse / Relay diagram for Vectra (1.8 SRi)
    By djhallam in forum Electrical & ICE (including SatNav)
    Last Post: 20th January 2008, 16:02
  5. Help With error CODES...!!??
    By sheiky in forum Engine & Drivetrain
    Last Post: 26th July 2007, 11:30
