Results 1 to 10 of 13
Thread: Another EGR post!!
    Jul 2012
    Shropshire
    Default Another EGR post!!
    Having the no power below 2k revs trouble. However, its not all the time. it started happening a few days ago and only seemed to happen after a short blast down a duel carriage way with my foot down then would be ok again after turning off for a few hours. Happening more often now, and at random times. she will drive fine for a while then loose low end power for a few mins, then back to normal. happens constantly. It is an intermittent problem, but is happening more often. Is it the EGR needs cleaning, boost pipes changing? or anything else. Also, the EGR, Swirl flaps/manifold were change by the previous owner only 10k mile ago to there expense of £900
    Engine : 1.9 CDTi
    Mine was doing the same and got worse and worse.
    Turned out that the egr solenoid was sticking now and again.
    Jul 2012
    Shropshire
    So just a good clean up should do the trick then?
    Engine : 1.9 CDTi
    It did with mine.
    Mar 2013
    reading
    Trim : sri
    Engine : 1.9 cdti 150
    just blocked mine off today, best thing ever done
    Feb 2013
    skinningrove cleveland
    Vehicle : vectra
    Trim : exclusive
    Engine : 1.9 cdti
    Mileage : 75500
    try cleaning boost sensor which is next to the egr valve , mine had same probs cleaned mine and now everything is good .
    Jul 2012
    Shropshire
    Quote Originally Posted by hicksy View Post
    Cleaned the EGR at my moms today, but still seemed laggy (not as bad) on the way home. Didn't do the boost sensor so could this be the problem? Swirl bar was changed about 10k miles ago and looked fine tday.
    Jul 2012
    Shropshire
    Anyone guys?? Sorry to keep bringing it up but it its really bugging me now. The egr was cleaned today but car is still lagging under 10k revs. Still intermittent ut not as bad as was before I cleaned egr. Would it be boost sensor needs cleaning and/or pipes need changing. Would doing these things solve it or could it be summat else? as said b4, swirl br looked fine and was changed at 44000 miles. car now at 55k. Thanks in advance ppl.
    Engine : 1.9 CDTi
    Did you see if the solenoid was nice and free by separating the 2 halfs?
    Mar 2013
    reading
    Trim : sri
    block egr off, live with the light, done mine today, mine was flat as anything upto the turbo kicks in.
    A lot more throttle response,
  1. can I post yet?
    By Neil in forum The 'Off Topic' room
    Last Post: 24th November 2011, 01:03
