Thread: 2.2 direct throttle body chicane/ tube/ gasket
    North East
    Default 2.2 direct throttle body chicane/ tube/ gasket
    Hi all.
    Ive just replaced my inlet manifold with sticky swirl valves for a sparkling clean one with nice and smooth flaps (you cant beat smooth flaps)
    I had a problem removing the throttle body off the old inlet manifold as one of the bolts had seized. I had to get a bit brutal with it to remove it. When I had removed it I think Ive dented the metal tube gasket that goes in before the throttle body, but the dent looks very symmetrical and I was wondering if it was supposed to be there or not?
    Can anyone shed any light on this. Ive put the car all back together and tested fine but I just have a slight feeling that the car is a little underpowered and this would tie up with a restriction in the throttle body tube. It might be just me though.
    Its number 15 in this picture.
    http://ecat24.com/opel/catalog/part/...68/4251/41383/
    Thanks in advance.
    Lee
    Jun 2011
    Fort William, Scotland
    Hi Lee - cant help with the throttle body issue but how much did it cost you to replce the inlet manifold, and apart from your issues with the throttle body, how hard was it to do?
    Apologies again
    Craig
    LARBERT
    Do not worry had it off a couple of time, the metal tube dent is normal and your right (you cant beat smooth flaps)
    Mar 2013
    south wales
    Vehicle : Vectra C facelift
    Trim : sri
    Engine : 2.2 Direct
    Mine is the same. On a seperate note. What is thr purpose of the metal tube?
  1. Throttle body gasket
    By Mark-R in forum Engine & Drivetrain
    Last Post: 13th February 2013, 22:22
  2. throttle body gasket
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2012, 11:49
  3. z20net throttle body gasket
    By beat275 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd September 2012, 01:05
