Thread: Placebo effect or quicker car?
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    Default Placebo effect or quicker car?
    Hi guys,
    Since taking my DT UK box off, my car has obviously felt a fair bit slower/less grunt.
    Since fitting my eBay bargain Powerflow exhaust, it's felt a fair bit more grunty again?!
    Through diesel tuning experience you see VERY little difference with just an exhaust, so I'm guessing this is just the placebo effect?
    This is my exhaust..
    Cheers, Jordan
    Regular Member Phil881's Avatar
    Sep 2012
    Edinburgh
    I know the feeling, I've just fitted an induction kit to my GSi
    It just seems quicker because you're using more right foot just to hear the noise for a little longer
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    the heart of diesel tuning is a good exhaust mate straight through is the way to go no cats ect
    South Central England
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I don't trust the bum at all for measuring performance. I know other 1.9CDTIs have gone from completely standard to full stainless exhaust and seen no difference at all on the rollers.
    Because demand is based on torque, unless you were torque limited by lambda calculations you would not see any difference in output from the engine. Torque is damanded by the accelerator, compared to the torque limiter, converted to an IQ based on rpm, that is limited by airflow, lambda, temperatures, vehicle speed, traction control, e.t.c; the IQ is then convered into a fuel pressure and duration and fuel is delivered with VNT duty adjusted to match the rpm and IQ while also monitoring the boost pressure for demand and limits and the ECU then measures the acceleration of the engine....
    Changing any part of the engine without changing the mapping is unlikely to show real performance gains.
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    276 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    I tend to agree with Nutron. However intake and exhaust modifications can reduce lag by improving airflow and so getting away from the smoke limiter quicker - hence allowing maximum fuel to be reached in a shorter time after planting the throtle. But for sustained full throttle, you'll see no difference without a remap.
    Feb 2013
    A Higher Level
    Vehicle : VECTRA C
    Trim : YES
    Engine : 1.9 CDTI
    Quote Originally Posted by paulvectrac View Post
    and one of your quality remaps as well
    Full Member Z80's Avatar
    Apr 2008
    Noumea
    16 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Free flow exhaust and intake will probably help the turbo spooling sooner (so do I actually hope), but other than that...
  1. 2.2 Direct has just got QUICKER :-/
    By neil3734 in forum The 'Off Topic' room
    Last Post: 31st March 2012, 09:05
  2. Which is quicker cavalier or vectra?
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2010, 17:46
  3. My latest mod , its now miles quicker
    By bobssignum in forum The 'Off Topic' room
    Last Post: 21st September 2010, 09:26
  4. getting quicker
    By aptoman in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2009, 17:53
  5. Servicing and the placebo effect
    By S888 SRB in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2007, 20:27
