Thread: loss of power in lower gears
    Jul 2010
    Bexley
    Default loss of power in lower gears
    Hi all,
    Can someone offer some advice please?
    I have a 2007 2.0L Signum, and today the spanner light has appeared on my dashboard and i have a loss of power in gears 1 and 2 when pulling away, the problem went when i stopped and restarted the car, but after a couple of mins i was back to having no power in lower gears again?
    can anyone pin point the problem please? thanks
    Regular Member JM53 BEL's Avatar
    Oct 2012
    Clackmannan, Scotland
    Trim : Elgance
    Engine : 2.0 Turbo
    Mileage : 106000
    Be best to get it hooked up to a code reader mate! Is it only lower gears or is it the rev range as you dont tend to go high up the revs in higher gears, also is it a turbine or NA ?
    Jul 2010
    Bexley
    Hi,
    it just seems to be in the the lower gears? when i get into 3rd i have much more power could it be the boost sensor or possibly throttle body perhaps?
    thanks mate
    Oct 2012
    Trim : Elgance
    Engine : 2.0 Turbo
    Mileage : 106000
    Not sure. As i would think if it was them the problem would be through the gears! @caveman nige would be best to ask on this but something definately up! Only time i got EML was before my turbo popped and the 2nd sensor on the exhaust picked up on emission problem cause i had airbox off to see if my down on power problem was a choked airfilter! Noticed my turbo sound like it was caughimg then about 3 weeks later turbo was dead!. Not sayin this is the fault you got as my power was down on all gears! Maybe give throttle body a clean aswell as boost sensor! Disconnect battery for 10-15 minutes to reset ECU if problems persist get fault codes read so you have better idea!
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by Tucker View Post
    Hi all,
    MAF sensor probably.
    I'm in Bexleyheath, pop over and I'll run a scan on it before 12:00 tomorrow.
    Jul 2010
    Bexley
    Hi,
    thanks for responding, i have pm you
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. no power in higher gears
    By porter1953 in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2010, 21:21
  3. loss of power
    By xc600 in forum Vectra C / Signum Troubleshooting
    Last Post: 14th December 2009, 21:25
  4. loss ov power
    By michael29 in forum Engine & Drivetrain
    Last Post: 28th February 2009, 16:50
  5. Auto box - total loss of gears
    By iddamsel in forum Engine & Drivetrain
    Last Post: 23rd March 2008, 15:03
