Results 1 to 10 of 16
Thread: No Blowers on any speed HELP
    Feb 2012
    Kent
    Default No Blowers on any speed HELP
    Have a Signum elite 7 speed auto climate control fan
    Had a funny smell the other day, and now no fans on any speed including 4 so not the resister problem
    What does this mean? Do i need a whole new heater and blower unit???? Whats my next steps
    Also how long to change this part out?
    Thanks in advanced
    Regular Member Vectra-c-SRI's Avatar
    May 2008
    Near Glasgow
    Engine : 1.9cdti 8v (120bhp)
    Mileage : 98000
    Vx replaced my control panel that worked. if you can get a loan of 2 try it you will know its that
    Regular Member STICKY3.2's Avatar
    Jul 2010
    Hertfordshire
    See if you can spin the motor I've seen one or two seize up, easy to remove just 4 screws in the housing behind/under the glove box
    Feb 2012
    Kent
    So its behind the glove box?
    Is the glove box easy to get out?
    I heard some can fill with water from the scuttle tray is this true?
    Jul 2010
    Hertfordshire
    Quote Originally Posted by scw02102 View Post
    Yes and yes. To get the glove box out, open it and just undo the screws top and bottom, (you may have to remove the trim panel under the glove box) slide it out, unplug the light and remove you should be able to see the heater box with the circular fan housing screwed up into it undo the screws and slide the fan assy out give it a spin!
    Jan 2013
    kent
    hi mate its jeff the man you got your rear bulb holders from i have all the parts you need and i am at my workshop tomorrow from 10 30 thanks jeff
    Regular Member Lordish's Avatar
    Feb 2012
    Luton
    Yes. My carpets got flooded from a blocked scuttle tray. A few weeks later my heaters packed up working. I too have the 7 speed climate. You may find that it's the resistor that has packed up. I got my new resistor from a member on here for a good price. The resistors are different for climate and non climate. And in the price too. The climate resistor you can get of eBay for 60-100 pounds. The glove box is very easy to take out. 5 screws ( 3 top 2 down or vice versa ). The resistor is a brake pad type shape and sits at the bottom of the fan. 2 screws to take out and it's plug and play. I changed this on mine and my climate worked again. Hope this helps
    Feb 2012
    Luton
    Thanks in advanced
    why would it not be the resistor if your climate is not working at all. Mine had a burning smell too before it packed up then no fans at all worked. Resistor solved the problem.
    Feb 2012
    Kent
    I read on here that the speed 4 always works and its the resistor if you are using other speeds sch as 3 and 2 etc...
    hopefully im wrong as the resistor is cheaper
    Jeff I will take it apart in the morning check and get back to you
    Feb 2012
    Luton
    I believe that is the case if its the normal 4 speed blowers and not the 7 speed climate. If the resistor goes in the 7 speed climate then it ALL stops working. Resistor for the 7 speed climate is up to 100 pounds rather than 15 for the normal 4 speed. You do have the 7 speed and not the 4?
  1. Leaf Vac / Blowers
    By Leemarksmith in forum General Chat
    Last Post: 4th November 2012, 16:35
  2. Blowers not working on any speed
    By noonaldinho in forum Electrical & ICE (including SatNav)
    Last Post: 22nd October 2012, 10:45
  3. blowers
    By bown in forum Introduce yourself.
    Last Post: 9th November 2010, 22:42
  4. blowers only working on speed 4
    By cooki in forum Bodywork & Interior
    Last Post: 5th December 2009, 21:30
  5. my blowers
    By stuee in forum Vectra C / Signum Car Chat
    Last Post: 27th December 2008, 12:39
