Thread: engine change
    Mar 2013
    reading
    Trim : sri
    Engine : 1.9 cdti 150
    Default engine change
    just wondering if i got the exact same engine (z19dth) for my vectra 05 plate, and wanted to swap;
    * what would need to do to ecu etc?
    * if the engine is out, is it easier to get clutch and flywheel done at same time?
    * anything else need to be done
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    u would need the ecu of the donor car
    Mar 2013
    reading
    Trim : sri
    and if didnt come with it?
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    usless unless it was programeed uo via tevh 2
    Regular Member ftm100's Avatar
    South Shields seagull sh*t town
    Thought it was only the injectors that were coded to the engine ?
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    wich is connected to the cim in a ideal world u need the cim moduals and ecu from donor car then it would just work
    Mar 2013
    reading
    Trim : sri
    so with my current ecu, it could be re programmed. just see a lot of used engines for sale, but not ecus with them
    not just easier than swapping injectors then?
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by scourslane View Post
    You can swap the engine with no problems so long as the vin numbers are in range for the engine code.(exact same engine)
    You dont need an ecu or anything else.
    Injectors
    1. use your old ones
    2. reprogram with tech 2 or Vaux-com
    3. dont do anything as they will re-learn after driving for 100 miles or so.
    Clutch
    Do this as its easy with the engine out.
    Mar 2013
    reading
    Trim : sri
    Cheers for the reply.
    mine is a 05 z19dth
    Looking at getting block and head with glow plugs, nothing else,
    rest of car would be my bits.
    Re clutch, guessing flywheel comes into this as easy to do as as well cheers pal
  1. engine change help
    By ros46si in forum Engine & Drivetrain
    Last Post: 7th October 2012, 21:48
  2. How often do you change your engine oil?
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2011, 13:32
  3. change my engine!!!
    By bedo13 in forum Tuning
    Last Post: 28th July 2010, 23:50
  4. dti engine change
    By driveryte in forum Engine & Drivetrain
    Last Post: 25th July 2010, 22:33
  5. Engine change
    By stevedee in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2008, 17:28
