Hi everyone. Recently I have replaced turbocharger and need to crack engine before starting my car. It is Vectra 1.9 CDTI 2006 and what to I need to disconnect to stop ignition?
Maybe take the fuse out for the fuel pump
I'm guessing to prime the turbo with oil? I just poured a little into mine when I was putting it together. It'll get oil pressure more or less instantly anyway.
Yes to prime the turbo. I have already injected oil into it but to be on safe side wanted crank the engine without ignition.
Unplug the injectors, it won't start then
I did this a couple of weeks ago. I disconnected each injector and cranked it 3 times for around 15 seconds (no more or you overheat starter motor) leave about a minute between each crank. Plug injectors back in and start her up. Just to be clear, I pulled each plug off the top of each inject, be careful with the little blue bits they snap easy.
just disconnect plug from the common rail.should only need to crank the engine couple of times, as said above, youll burn the motor out with prolonged cranking!
Just run it up and let oil run through. 30 secs turn off. Top up oil go again do it 3/ 4 times and its gives an accurate info on the amount of oil going through turbo when vehicle running
