Thread: Live data....Can Anyone Shed Some Light On These Please!
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Default Live data....Can Anyone Shed Some Light On These Please!
    I have no Eml lights or stored codes on the car and the car drives fine but I do have some red discrepancies which are flagged when I look at the live data!
    Screen shot.
    The data Its highlighted in bold where the failed parameters have been recorded. Can anyone shed any light on what or if anything needs to be done.
    Mode $06 report generated by Torque for Android ================================================ Vehicle VIN: Not present Vehicle Manufacturer: Unknown Vehicle Calibration ID: Not present Test report: ------------------ MID:$01 TID:$01 Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 1 Max: 0.45103V Min: 0.45103V Test result value: 0.45103V PASS ---- MID:$01 TID:$02 Lean to Rich sensor threshold voltage(constant) - O2 Bank 1 Sensor 1 Max: 0.45103V Min: 0.45103V Test result value: 0.45103V PASS ---- MID:$01 TID:$07 Minimum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 1 Max: 0.39918V Min: 0V Test result value: 0.0466V PASS ---- MID:$01 TID:$08 Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 1 Max: 1.04737V Min: 0.49776V Test result value: 0.79324V PASS ---- MID:$01 TID:$09 Time between sensor transitions(calculated) - O2 Bank 1 Sensor 1 Max: 1,520ms Min: 40ms Test result value: 200ms PASS ---- MID:$01 TID:$88 - O2 Bank 1 Sensor 1 Max: 1,880ms Min: 0ms Test result value: 500ms PASS ---- MID:$01 TID:$89 - O2 Bank 1 Sensor 1 Max: 800ms Min: -800ms Test result value: 149ms PASS ---- MID:$02 TID:$01 Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 2 Max: 0.59621V Min: 0.59621V Test result value: 0.59621V PASS ---- MID:$02 TID:$02 Lean to Rich sensor threshold voltage(constant) - O2 Bank 1 Sensor 2 Max: 0.59621V Min: 0.59621V Test result value: 0.59621V PASS ---- MID:$02 TID:$07 Minimum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2 Max: 0.39918V Min: 0V Test result value: 0V PASS ---- MID:$02 TID:$08 Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2 Max: 1.04737V Min: 0.49776V Test result value: 0.89694V PASS ---- MID:$05 TID:$01 Rich to Lean sensor threshold voltage(constant) - O2 Bank 2 Sensor 1 Max: 0.45103V Min: 0.45103V Test result value: 0.45103V PASS ---- MID:$05 TID:$02 Lean to Rich sensor threshold voltage(constant) - O2 Bank 2 Sensor 1 Max: 0.45103V Min: 0.45103V Test result value: 0.45103V PASS ---- MID:$05 TID:$07 Minimum sensor Voltage for test cycle(calculated) - O2 Bank 2 Sensor 1 Max: 0.39918V Min: 0V Test result value: 0.0466V PASS ---- MID:$05 TID:$08 Maximum sensor Voltage for test cycle(calculated) - O2 Bank 2 Sensor 1 Max: 1.04737V Min: 0.49776V Test result value: 0.79849V PASS ---- MID:$05 TID:$09 Time between sensor transitions(calculated) - O2 Bank 2 Sensor 1 Max: 1,520ms Min: 40ms Test result value: 200ms PASS ---- MID:$05 TID:$88 - O2 Bank 2 Sensor 1 Max: 1,880ms Min: 0ms Test result value: 440ms PASS ---- MID:$05 TID:$89 - O2 Bank 2 Sensor 1 Max: 800ms Min: -800ms Test result value: 168ms PASS ---- MID:$06 TID:$01 Rich to Lean sensor threshold voltage(constant) - O2 Bank 2 Sensor 2 Max: 0.59621V Min: 0.59621V Test result value: 0.59621V PASS ---- MID:$06 TID:$02 Lean to Rich sensor threshold voltage(constant) - O2 Bank 2 Sensor 2 Max: 0.59621V Min: 0.59621V Test result value: 0.59621V PASS ---- MID:$06 TID:$07 Minimum sensor Voltage for test cycle(calculated) - O2 Bank 2 Sensor 2 Max: 0.39918V Min: 0V Test result value: 0V PASS ---- MID:$06 TID:$08 Maximum sensor Voltage for test cycle(calculated) - O2 Bank 2 Sensor 2 Max: 1.04737V Min: 0.49776V Test result value: 0.88657V PASS ---- MID:$10 TID:$e7 - O2 Bank 4 Sensor 4 Max: 40,983ms Min: 20,592ms Test result value: 59,152ms FAIL ---- MID:$21 TID:$80 - Catalyst Monitor Bank 1 Max: 0.64026 Min: 0.21472 Test result value: 0.21472 PASS ---- MID:$22 TID:$80 - Catalyst Monitor Bank 2 Max: 0.64026 Min: 0.08589 Test result value: 0.08589 PASS ---- MID:$3d TID:$82 - EVAP Monitor (0.020") Max: 0.07085 Min: 0.06997 Test result value: 0.07085 PASS ---- MID:$41 TID:$81 - O2 Heater Monitor Bank 1 - Sensor 1 Max: 1,920Ohm Min: 0Ohm Test result value: 126Ohm PASS ---- MID:$42 TID:$81 - O2 Heater Monitor Bank 1 - Sensor 2 Max: 2,280Ohm Min: 0Ohm Test result value: 124Ohm PASS ---- MID:$45 TID:$81 - O2 Heater Monitor Bank 2 - Sensor 1 Max: 2,010Ohm Min: 0Ohm Test result value: 116Ohm PASS ---- MID:$46 TID:$81 - O2 Heater Monitor Bank 2 - Sensor 2 Max: 2,160Ohm Min: 0Ohm Test result value: 96Ohm PASS ---- MID:$5f TID:$ce - Max: 0 Min: 0 Test result value: 12,800 FAIL ---- MID:$71 TID:$31 - Secondary Air Monitor 1 Max: 40,960 Min: 24,688 Test result value: 12,656 FAIL ---- MID:$81 TID:$80 - Fuel System Monitor Bank 1 Max: 8.48% Min: -8.49% Test result value: -0.15% PASS ---- MID:$81 TID:$82 - Fuel System Monitor Bank 1 Max: 1.2293 Min: 0.76955 Test result value: 1.02181 PASS ---- MID:$81 TID:$83 - Fuel System Monitor Bank 1 Test incomplete or dependant test failed -- MID:$82 TID:$80 - Fuel System Monitor Bank 2 Max: 8.48% Min: -8.49% Test result value: -0.1% PASS ---- MID:$82 TID:$82 - Fuel System Monitor Bank 2 Max: 1.2293 Min: 0.76955 Test result value: 1.02087 PASS ---- MID:$82 TID:$83 - Fuel System Monitor Bank 2 Test incomplete or dependant test failed -- MID:$8f TID:$ce - Max: 0 Min: 0 Test result value: 12,800 FAIL ---- MID:$a1 TID:$80 - Misfire Monitor General Data Max: 110 Min: 0 Test result value: 0 PASS ---- MID:$a1 TID:$81 - Misfire Monitor General Data Max: 3,200 Min: 0 Test result value: 0 PASS ---- MID:$a2 TID:$80 - Misfire Cylinder 1 Data Max: 110 Min: 0 Test result value: 0 PASS ---- MID:$a2 TID:$81 - Misfire Cylinder 1 Data Max: 3,200 Min: 0 Test result value: 0 PASS ---- MID:$a3 TID:$80 - Misfire Cylinder 2 Data Max: 110 Min: 0 Test result value: 0 PASS ---- MID:$a3 TID:$81 - Misfire Cylinder 2 Data Max: 3,200 Min: 0 Test result value: 0 PASS ---- MID:$a4 TID:$80 - Misfire Cylinder 3 Data Max: 110 Min: 0 Test result value: 0 PASS ---- MID:$a4 TID:$81 - Misfire Cylinder 3 Data Max: 3,200 Min: 0 Test result value: 0 PASS ---- MID:$a5 TID:$80 - Misfire Cylinder 4 Data Max: 110 Min: 0 Test result value: 0 PASS ---- MID:$a5 TID:$81 - Misfire Cylinder 4 Data Max: 3,200 Min: 0 Test result value: 0 PASS ---- MID:$a6 TID:$80 - Misfire Cylinder 5 Data Max: 110 Min: 0 Test result value: 0 PASS ---- MID:$a6 TID:$81 - Misfire Cylinder 5 Data Max: 3,200 Min: 0 Test result value: 0 PASS ---- MID:$a7 TID:$80 - Misfire Cylinder 6 Data Max: 110 Min: 0 Test result value: 0 PASS ---- MID:$a7 TID:$81 - Misfire Cylinder 6 Data Max: 3,200 Min: 0 Test result value: 0 PASS ---- MID:$e6 TID:$28 Manufacturer defined MID - Max: 20,480 Min: 6,192 Test result value: 55,064 FAIL ---- MID:$f6 TID:$28 Manufacturer defined MID - Max: 20,480 Min: 10,288 Test result value: 55,064 FAIL ---- End of report.
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    clear the faults then try again sometimes things like opcom can make errors show up all over the place
    Trim : Sport
    Engine : Petrol
    There's no faults to clear from the ecu
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Have a Tech 2 session or Vaux-com
    Those generic software downloads can throw all sorts of stuff.
    Trim : Sport
    Engine : Petrol
    It looks pretty comprehensive to me....... The cars running ok but I'm a little concerned about bank 4 do I need to change the sensor?
    Trim : Sport
    Engine : Petrol
    Anyone have any more ideas?
    May 2011
    South London
    Well everything's already been mentioned.
    Tech 2 or Vaux com will find error codes that other codes readers don't.
    You seriously trust a generic code reading Android app to in depth diagnose a fuelling problem ?
    http://www.youtube.com/watch?v=zUlGunZ5QAo
    Trim : Sport
    Engine : Petrol
    Quote Originally Posted by C-Owner View Post
    Thanks for the input fella I was just hoping that someone could come up with a little more insight. I can see that some bits are running outside the set parameters hence the fail status.
    The two in green are no longer showing, I re-tested as it says test incomplete now I only have the two fails showing.
    I think Ill change the O2 sensor on bank 4 sensor 4 as it looks like its on its way out, or would something else cause this to over read?
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Where do you get live readings? Ive been needing some for a while to cure p0170 po100 codes but dont know where to turn too!
    Trim : Sport
    Engine : Petrol
    Dont think I even have a bank 4 lol, bank 1 & 2 yes up stream and down stream. its probably the generic software playing games or is it?
  1. 2003 vectra c 1.8 misfire Live data
    By andymeeson in forum Engine & Drivetrain
    Last Post: 29th January 2013, 20:55
  2. Birmingham - Code reader / live data reader
    By awilson1234 in forum Engine & Drivetrain
    Last Post: 26th September 2011, 16:55
  3. Live Data from test - no faults stored
    By ScottyV6 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd June 2011, 20:28
  4. tech 2 live data
    By Morephun in forum Engine & Drivetrain
    Last Post: 25th February 2009, 22:15
  5. can u shed any light?
    By jun in forum Electrical & ICE (including SatNav)
    Last Post: 12th January 2009, 14:42
fuel system monitor bank 1 vectra
MID: 10 TID:e6
Catalyst monitor bank 1 test incomplete
mid:10 tid:e7
Time between sensor transitions(calculated) - O2 Bank 1 Sensor 1 Test incomplete or dependant test failed Sensor period(calculated) - O2 Bank 1 Sensor 1 Test incomplete or dependant test failed vauxhal l
A1 misfire monitor general data
vauxhall catalyst monitor bank 1
TID:86 insignia
mid:se2 TID:86
mid 5f tid:ce not ok
manufacturer defined mid insignia
o2 heater monitor bank 1 sensor 2 vectra c
rich to lean sensor threshold voltage(constant) oprl
Fuel System Monitor Bank1
Mid:5f
