Thread: Engine management light!!
    Mar 2012
    England
    Default Engine management light!!
    I have a Vectra 1.8 SRi on an 07 plate, i changed the part of the exhaust today with the flexi pipe and the sensor on it.
    At first the car was fine and i had no fault lights. Then after about ten miles the management light came on.
    I have managed to find out that the code is P0135 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 1) C-29.
    Everything was fine before i changed it and all was fine at first. Can anyone actually explain what this code means??
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    That is for the o2 sensor on the manifold, prior to the cat. Try getting the code reset and see if it comes back up.
    Mar 2012
    England
    Is it definitely the one prior to the cat? Thought i might of damaged something whilst changing the exhaust.
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
    Yes sensor 1 is the one prior to the manicat. Sensor 2 the one after the flexi.
    East Ayrshire
    Trim : SRI XP1
    have you checked to make sure the connector hasn't popped off
    Mar 2012
    England
    Not yet i will have to get it back on the ramp to check. Do you know if vauxhall charge to reset EML??
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
    Yes they will. You can buy a generic fault code reader off ebay for about £20, which is about a 1/3 of what vx will charge you, and come in handy. I have a D900 which does the job for me.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
