Hi All
Does anyone have a step by step on how to remove the gearbox to change the clutch on a 2004 vectra C 1.8cc
Many Thanks
BFC1965
Hi All
Many Thanks
BFC1965
Remove batt & trtray
pop off gear cables
remove road wheels
discinnect drop links, track rods, lower arm ball joints
disconnect steering uj (ensure key out ign and steering lock on)
remove power steering electrics
Remove lower engine support brackets
undo subframe and lower and leave O/s/f corner bolt in place or remove sub frame fully
remove starter
remove all bell housing bolts
support box and remove gearbox mount bolts
lower box
job done.
Hi thanks for your quick responce
Is this job easy or a pain i have read thats it hard to do, but by your instructions it sound easy is there any problems i mite encounter along the way
Depends mate
how good you are with spanners
vecs are probably one of the more pain in the arse clutches to do be side of subframe.
their not massively hard to do just very time consuming.
i would say a full weekends work if doing on back.
On drive
Many thanks Critch for your help will start it in the morning
No worries
any time mate
